 Post subject: non-responsive if clicked at edge of icon
PostPosted: Tue Mar 07, 2023 11:58 pm
Nexus.exe 22.07.1179, everything current:
Noticed occasionally that clicking an icon would not launch and felt weird.
Did some analysis, discovered that clicking the left or rightmost edge of an icon at the very last edge pixel would cause the mousedown/mouseup animation to fire, but no icon launch and the visual effect applied to the icon does not fire. I reduced horizontal spacing to the lowest amount and it did not help.
wsbackup attached
File comment: settings backup.
wsbackup.zip [10.27 KiB]
Downloaded 738 times
 Post subject: Re: non-responsive if clicked at edge of icon
PostPosted: Wed Mar 08, 2023 1:51 am
wsbackup attached
This has been discussed here before - do a search!
PostPosted: Fri Mar 10, 2023 1:36 am
I said the bug was dumb, not you. Abuse? Chill. Fix your code and thank users who report problems with detailed information. This clearly is not a desired feature of the software and makes no sense from a GUI point of view. It should not animate if it does not intend to launch the app.
Users browsing this forum: Google [Bot] and 191 guests
