 Post subject: DisplayFusion Fix of Sys Tray / Win 11 Issue
PostPosted: Wed Apr 12, 2023 6:51 pm
Member Solamain reports that DisplayFusion has fixed its System Tray/Windows 11 issue. So any DF users out there under Win 11, you know what to do for now. :)
Unfortunately, however, DF is not likely to have been coded in the same language as Winstep apps, which is where the problem in finding a solution lies, thanks to Microsoft's throwing more and more spanners into the works for Win32 coders. :(
Have a look at DF's forum HERE, courtesy of Solamain. 8)
 Post subject: Re: DisplayFusion Fix of Sys Tray / Win 11 Issue
PostPosted: Tue Apr 18, 2023 2:11 pm
'Bump Topic' not available, so this is just a booster.
Users browsing this forum: Amazon [Bot] and 175 guests
