 Post subject: System Tray Button doesn't seem to work
PostPosted: Wed Sep 06, 2023 4:11 pm
Basically when I click in the System Tray Button no icons are displayed. Before I tried to fix it, a message that said that "the icons are hidden" or something similar appeared but now it just does nothing.
 Post subject: Re: System Tray Button doesn't seem to work
PostPosted: Thu Sep 07, 2023 12:52 am
Details, details, details - the devil's in them! See the Board Rules and Guidelines concerning this and other guidelines and tips about posting.
PostPosted: Tue Sep 12, 2023 12:08 pm
Are you running Windows 11 22H2?
PostPosted: Tue Sep 12, 2023 1:54 pm
Yes, that is the correct!
PostPosted: Tue Sep 12, 2023 5:30 pm
Please read THIS then.
The Winstep Xtreme/Nexus Ultimate v23.7 beta kind of mitigates this issue but does not fix it.
PostPosted: Tue Sep 12, 2023 5:34 pm
Would it be better to downgrade? go to 21h2?
PostPosted: Tue Sep 12, 2023 5:46 pm
That would fix all the system tray issues, yes. That's what I would have personally done here if I could, since 22H2 is absolutely riddled with bugs too (e.g. Windows reporting incorrect per-process CPU usage, among others) which Microsoft seems determined in not fixing despite 22H2 being out for many months now.
PostPosted: Tue Sep 12, 2023 6:01 pm
I looked out how to go to 21h2... is it possible to do it without loosing all my files?
PostPosted: Tue Sep 12, 2023 6:07 pm
Unless you just installed 22H2 on top of 21H2 (i.e. in the last 30 days IIRC), you will have to do a clean install of Windows 11 21H2.
PostPosted: Tue Sep 12, 2023 6:42 pm
Alright thank you!
Users browsing this forum: Google [Bot] and 194 guests
