 Post subject: Version rollback instruction
PostPosted: Thu Dec 14, 2023 8:57 pm
Apologies for the basic question, but I have not got a lot of time to search around.
I reinstalled Winstep recently and just realized that I have installed a newer version that is not covered under my previous license. How do I roll back to an older version? I'm perfectly happy with the old one.
Thank you.
 Post subject: Re: Version rollback instruction
PostPosted: Thu Dec 14, 2023 9:11 pm
How did you install the new version (Winstep Update Manager or via the Winstep web site)? If the latter, did you install on top of an existing installation or from scratch? Are you running Nexus Ultimate or Winstep Xtreme?
PostPosted: Sat Dec 16, 2023 3:36 am
It was via the Winstep website, as per the instructions from my email receipt. I am running Nexus Ultimate.
I did uninstall my previous version of Nexus Ultimate before running the installation of this version, but the settings were kept between the two versions.
PostPosted: Sat Dec 16, 2023 3:41 am
Well, try the following then: open Preferences, since your license key no longer supports the newer version the Register tab should have made a come back. Click on the Register tab.
On this tab there should be a link to roll back to the previous version. Click it and let me know how it went please, I haven't touched the roll back code in years lol
PostPosted: Mon Dec 18, 2023 8:48 pm
Could not seem to find the rollback link in the Register tab. My license expires last September if it is any help.
PostPosted: Mon Dec 18, 2023 9:07 pm
Thanks for the screenshot. If the Roll Back link does not appear, that's because there is no previous version to roll back to (which happened when you uninstalled the previous version, I missed that part).
Anyway, I'll send you a PM with a link to v22.7.
Users browsing this forum: Google [Bot] and 205 guests
