 Post subject: Could not remove sub-dock indicator
PostPosted: Tue Dec 19, 2023 9:56 pm
I did this once, but somehow I could not figure out how to replicate it upon the recent reinstallation of Nexus Ultimate. The indicators were using arrows from K-TEK 4D and then somehow changed to the current ones, which look similar to the files in DarkTech and Office. Since then, the indicators don't change at all when I swap between different themes.
What I have done so far:
- Moved the arrow icons from Themes/DarkTech, Themes/K-TEK 4D, and Themes/Office to somewhere else. Which in my mind should prevent Nexus from reading those files.
- Set the shelf theme to DarkTech.
 Post subject: Re: Could not remove sub-dock indicator
PostPosted: Tue Dec 19, 2023 10:50 pm
Those are the *default* sub-dock indicator arrows - that's what the application will use if the theme used by that dock does not provide its own sub-dock indicator bitmaps (nxSubC.ico/.png/.tif)
You have the background of that dock set to fully transparent, so it's not possible to know which theme the dock is using - but whatever it is, it does not have a nxSubC.ico/.png/.tif file.
PostPosted: Thu Dec 21, 2023 3:24 am
It is running DarkTech with all arrow icons removed, so it makes sense that the program is running the default arrows. Is there a way to turn off the default arrows? Alternatively, I could create a transparent nxSubC icon file if that works.
PostPosted: Thu Dec 21, 2023 3:38 am
This ^
PostPosted: Sat Dec 23, 2023 7:18 am
Happy to report that the idea worked like a charm. Topic resolved.
Users browsing this forum: Amazon [Bot] and 197 guests
