 Post subject: Unable to update
PostPosted: Tue Jan 02, 2024 3:55 pm
Got a popup saying an update was available, so I clicked to download it and this popped up
I've tried a few times now and still get the same, please help
Edited to add, I even tried disabling AV
 Post subject: Re: Unable to update
PostPosted: Thu Jan 04, 2024 6:39 am
Oh, that is your AV alright. What AV are you using? Windows Defender?
If I recall correctly, one user had to temporarily disable their AV **and** restart the system for it to work. Give that a try and let me know, please. If that doesn't work either we can try bypassing the Winstep Update Manager.
We're getting to a point where AV software is actually CREATING more problems than it solves.
PostPosted: Thu Jan 11, 2024 3:54 pm
Thank you for your suggestion. I disabled my AV (avast) from startup and rebooted. Unfortunately I am still getting the same message that download failed :?
PostPosted: Thu Jan 11, 2024 4:29 pm
Go to
C:\Users\Public\Documents\WinStep\Versions
can you post a screenshot here showing the contents of that folder please?
PostPosted: Thu Jan 11, 2024 6:50 pm
PostPosted: Thu Jan 11, 2024 8:30 pm
Cool, thanks! Can you manually unzip ultimate-exe.zip ?
Inside there should be a setup.exe and a ReadMe.txt file.
PostPosted: Thu Jan 11, 2024 10:11 pm
Yes I was able to unzip and successfully run the setup, following the instructions in the read me file
Thank you! :D
Users browsing this forum: Amazon [Bot] and 170 guests
