Board index : Winstep Forums : Off Topic  [ 5 posts ]
 Post subject: Question on Winsteps measure criteria for anchor items
PostPosted: Thu Mar 14, 2024 7:43 am
Hello,
I've recently analysed some old data with the Winsteps software (that performs Rasch measurement and analysis), using a dozen anchor items from a previous test.I can't find any piece of information about the specific measure values taken by anchor items : in my data, it is 0, 1 or -1.
How should I interpret those data ?
Thanks in advance for your help !
Regards,
Keith
"Life is a beautiful journey that is meant to be embraced to the fullest every day uno online"
 Post subject: Re: Question on Winsteps measure criteria for anchor items
PostPosted: Thu Mar 14, 2024 1:45 pm
You're in the wrong forum, this is for Windows customization software. What you want is
https://www.winsteps.com/index.htm
PostPosted: Fri Mar 15, 2024 1:21 am
So sorry. Thanks for your instruction
 Post subject: Winsteps measure criteria for anchor items
PostPosted: Wed Apr 23, 2025 6:45 am
Hi there ! I've recently analysed some old data with the Winsteps software (that performs Rasch measurement and analysis), using a dozen anchor items from a previous test.I can't find any piece of information about the specific measure values taken by anchor items : in my data, it is 0, 1 or -1.
How should I interpret those data ? Is it the program that "deactivates" the measure in order to rely only on the displacement value that it shows? The displacement direction and new measure values do not seem to be correlated. Thanks in advance for your help !
 Post subject: Re: Winsteps measure criteria for anchor items
PostPosted: Wed Apr 23, 2025 8:52 am
Academic types sure are distracted :D : you're in the wrong website and forum.
This forum is for Winstep Windows customization software. What you want is
Winsteps and Facets: Rasch Analysis + Rasch Measurement Software
Look carefully *at the bottom* of that page for a link to a Rasch Measurement forum and also a contact email address.
Post new topic Reply to topic Board index : Winstep Forums : Off Topic  [ 5 posts ]
Users browsing this forum: No registered users and 38 guests
