 Post subject: System tray not displaying in Dock ?
PostPosted: Mon Dec 11, 2023 4:07 am
Hi,
I am new to Winstep/Nexus. I was setting it up and I see that I don't have system tray in my dock even when I have selected the "Show system tray in this dock option". I know customizing the tray icons is a paid feature, but I believe displaying system tray icons is not.
Is there something i am missing here. Sorry, new user and thank you.
 Post subject: Re: System tray not displaying in Dock ?
PostPosted: Mon Dec 11, 2023 5:04 am
Starting with Windows 11 22H2, and mostly for purely cosmetic reasons, Microsoft has begun making changes to tried and tested core functions of Windows that had previously been working fine for decades.
Windows 11 22H2 made many core changes to the Windows taskbar and systray. As a result systray icons can no longer be accessed directly by Winstep applications, and while v23.11 offers some temporary mitigations (giving you access to the main systray volume/network/etc panel and to the systray overflow area) this does require the user to disable the 'Always show all system tray icons' setting in the Winstep application - plus system tray icon customization with high resolution icons is currently no longer possible.
PostPosted: Thu Dec 14, 2023 5:40 am
Other issues with the tray even with the 23.11 update:
1. I used to have my right dock be only the system tray. While I can create such a dock it never unhides when bumping the screen edge. If I go to the dock properties it appears where I expect it but not when running the dock. Keeping it visible fixes that but isn't ideal.
2. If I add the system tray to a dock with other icons it also adds the network icon link which I don't want. Funny that doesn't happen when it's the systray alone but see above for what does happen.
3. It seems Microsoft themselves removed the show all system tray icons option although it APPEARS it can be turned on running this command:
explorer shell:::{05d7b0f4-2121-4eff-bf6b-ed3f69b894d9} and checking the box. Unfortunately, it neither helps the situation nor actually works to show all icons. Dragging the hidden icons to the taskbar means the icon will not display in the dock.
PostPosted: Sun May 12, 2024 5:52 pm
Winstep wrote:
...systray icons can no longer be accessed directly...
I discovered this by accident today. I had several programs that were not showing in the system tray overflow area. All of these items were set to "On" in the Windows 11 "taskbar/personalization/other system tray icons" settings. When I switched them to off they became visible in the overflow area again. Checking "Show system tray in this dock" added the system tray to my dock with access to the overflow area and the missing icons. I am using Winstep Xtreme 24.4 on Windows 11 23H2.
PostPosted: Sun May 12, 2024 8:18 pm
How very queer! Win 11 seems to be getting almost as freakish as that annual freak show that finished last night in Sweden. ;)
PostPosted: Wed May 15, 2024 10:48 am
Thanks for the info, I had the same problem, now I know how to solve it :)
PostPosted: Fri May 17, 2024 4:00 pm
smithloo wrote:
interesting topic
thanks for useful responses
Full of shit, eh? :P :twisted:
PostPosted: Sat Aug 31, 2024 2:47 am
The fix I found for this was installing explorer patcher, which is nice to have anyway. With it you can select the option for the taskbar style to Windows 10. For me, it auto selected it automatically on install. This "opens the door" allowing Winstep to access the system tray information that it used to have access to.
PostPosted: Sun Sep 01, 2024 2:28 am
Hmmm... Why do I smell a...?
PostPosted: Sun Sep 01, 2024 8:24 am
Nothing on stop forum spam yet...
PostPosted: Fri Oct 04, 2024 2:07 am
Looks like that's open source free software so I doubt there's any ill intent.
Update:
I downloaded the app and it does fix the system tray issue. At least until the next Windows update.
PostPosted: Sun Nov 03, 2024 12:39 am
As a user who has just upgraded to Windows 11 and didn't like losing my system dock, I thought it was posting to support the fix indicated above.
I installed the Explorer Patcher software from here:
https://github.com/valinet/ExplorerPatc ... me-ov-file
It is a simple .exe that allows you to change Windows 11 features back to the Windows 10 versions. Things like the way the Taskbar looks. As such, it is a useful utility and it does, indeed, solve the system tray issue with Nexus. You do need to add exclusions to Windows Defender (and presumably other antivirus software) to make it run though.
Users browsing this forum: Amazon [Bot], Google [Bot] and 164 guests
