 Post subject: Shortcuts in folders dont work
PostPosted: Fri Sep 27, 2024 12:51 pm
Hi guys.
I made a folder containing shortcuts on my desktop. I drugged this folder in Nexus. From its properties, I set it to open as a menu. It appears correct but when I click on a shortcut nothing happens.
It used to work fine but for some reason, it doesn't anymore.
And this feature is the one I need most from nexus.
Can anyone help?
 Post subject: Re: Shortcuts in folders dont work
PostPosted: Fri Sep 27, 2024 8:31 pm
yan wrote:
Hi guys.
Can anyone help?
Not enough details. See Board Rules & Guidelines for help with posting.
PostPosted: Fri Sep 27, 2024 10:19 pm
I took shortcuts from my desktop and put them in a folder. I drugged this folder into nexus. When you click that folder it opens an explorer window. But if you go to the nexus properties of this folder and choose to open as a menu, then, when you click on it it shows a list of the shortcuts in the folder. When you click on a shortcut it should open the program associated. But it does nothing.
This used to work a few days ago. Now it does not.
PostPosted: Sat Sep 28, 2024 4:43 am
Just what part of 'Not enough details' do you not understand!?
PostPosted: Sun Sep 29, 2024 3:40 pm
What changed in your system between then and now? Also, have you already rebooted your PC?
Users browsing this forum: Amazon [Bot], Bing [Bot] and 212 guests
