 Post subject: So close and yet so far
PostPosted: Thu Jan 27, 2005 4:58 pm
Hi!
I've been trying to find a replacement for DragThing on Mac OS X, and Workshelf is very close. It only has two very annoying aspects (for me at least)
a) I have tuned it so I have to click along the top to get the tab to open - taking advantage of fitt's law and stopping the shelves opening by accident. But the auto-hide works doesn't work properly like this: if I leave the mouse where it is (along the top edge, remember that Edge Bump is off) then the shelves disappear as if the mouse wasn't actually residing on the shelves - very annoying!
All this requires is for the 'hotspot' that keeps the shelves open to include the top/bottom edge of the screen
b) The selection area for the icons is a nice rounded rectangle surrounding them. Leaving about 30 pixels between each that does nothing. not to mention that they don't touch the edge of the screen (again).
Why not make the selection area for icons as big as possible, touching each other? And if they extended all the way to the edge then the most frequent items, when up against the edge, would be tremendously easy and fast to select.
And that's what this software is all about, isn't it?
(And in fact, extending the tiles to the edge would fix problem A as well...)
Anyway, I will try to use the software for a month and see how useful I find it. Apart from the above it seems very solid.
 Post subject: Re: So close and yet so far
PostPosted: Thu Feb 17, 2005 4:50 pm
Sorry for the late reply...
All this requires is for the 'hotspot' that keeps the shelves open to include the top/bottom edge of the screen.
I'm not sure I follow... Edge bump is off but you click on the top edge to open WorkShelf? Hmm... Where exactly are you clicking on then? And can I assume that the shelf is docked to the top edge?
Because you need that 'empty' space between items in order to insert new items at that position with drag & drop, to drag the shelf around when undocked - otherwise you would instead drag the selected object - and to be able to add new items via the right click context menu. You can actually reduce this 'empty' space by decreasing the Horizontal Icon Spacing in the Shelf Preferences tab.
Users browsing this forum: ppetroff60 and 175 guests
