 Post subject: Decrease distance between icons
PostPosted: Fri Jun 06, 2025 6:06 am
How can I further decrease the horizontal distance between the icons...with the settings this is the minimum, but is there a way to decrease it further?
Thank
Kira
 Post subject: Re: Decrease distance between icons
PostPosted: Fri Jun 06, 2025 7:08 am
Thanks for the screenshot, without it it would probably not have been possible to figure out what is REALLY going on, at least not in a timely manner.
Your problem is not the icon spacing, but the fact that you are using a TILED theme for the dock (which is not visible in the actual dock at the bottom of the screenshot likely because the dock background is set to be 100% transparent). The tiles themselves have non-stretchable edges that are added to the icon spacing, so that the icons do not overlap the tile edges (hope that makes sense) - this is what is preventing the icons from being tighter together.
In short, the solution to your problem: apply a theme to the dock that is NOT based on tiles.
PostPosted: Sat Jun 07, 2025 5:08 am
Yessss you are right and thank for your help
I solved using Windows10nx
Good weekend
Kira
Users browsing this forum: Google [Bot] and 188 guests
