Board index : Winstep Forums : General Discussion  [ 1055 posts ] Go to page Previous  1 ... 59, 60, 61, 62, 63, 64, 65 ... 71  Next
PostPosted: Fri Jul 11, 2025 8:51 am
On the other hand, you can already (i.e. in the next release) right click on folder menus and sort them by name, type, date created, date modified and size (ascending and descending).
You mean in the upcoming release or latest one, as I can't find it anywhere in current version. Is there any release date planned for next version or is there a beta version available to download?
BTW I've another suggestion to make, or maybe rather a question as well - is it just me that doesn't know how to handle this automatically, but when I move dock from bottom to left side, I need to change indicator every time when I want to have indicator always close to the edge of the screen. I know I can have indicators below the icons every time I change dock position, but I don't want that.
File comment: So this is how it looks when it's on the bottom
File comment: That's how it looks when I move it to the left
File comment: I want it to look like this without having to change indicator image
PostPosted: Fri Jul 11, 2025 6:26 pm
Upcoming release. Release should be soon (as in next week or so).
Indicators by default are always set to be bellow (at the base of) the icons even in vertical docks. Try opening the dock properties window, navigating to the Appearance tab, clicking the Indicator Offset button and then clearing the 'Always at the base of the icon' checkbox.
This said, I wrote that part of the code many years ago and from what I have just tried right now, it seems a bit buggy when "always at the base of the icon" is not set as I do not see the running indicator for vertical docks on the right side of the screen. Will have to look deeper into this.
PostPosted: Mon Jul 14, 2025 3:47 am
This is good news. Well done for supporting this project for many years.
Wanna jack vids from @fineasslatinas or rip that fire track that dropped at 3am? saveinsta.name laughs at paywalls while ytmp3safe.com chugs beers and shits out crystal clear mp3 faster than your broke wifi loads porn. Just paste the damn link like u do when u DM weird stickers, tap the fat download arrow, boom the reel of that thick goth chick flashes on your phone or the emo banger plays in ur shit car stereo. Both totally free no sparkling bullshit surveys boot lickers begging for credit card numbers, just grab em sluts outta IG and grab them shit tracks before the label assholes yank em Guess Ill stumble off for another shot now bye
PostPosted: Mon Jul 14, 2025 6:12 pm
I would like to see an option for a default Windows 10 and Windows 11 theme. I really like Winstep Xtreme but I am getting tired of themes.
PostPosted: Mon Jul 14, 2025 6:31 pm
Well, I don't usually do themes, users do, but have you tried DarkTech already? If you use dark mode in Windows it is pretty similar (and what I use here all the time, I don't really care about themes either).
PostPosted: Mon Jul 14, 2025 11:34 pm
I used DarkTech for a long time when I first got Winstep Xtreme.
Maybe JCRabbit will come out of retirement. :wink:
I played around with WebGizmos Naked1 theme and this is what I came up with.
It would also be nice if I could combine the Winstep Start Menu with the Start Grid Stack that I created. The two of them together would make a great Start Menu replacement. Maybe that's a new feature for the future.
Unfortunately that is the extent of my theming abilities. Maybe someone will take that idea and run with it.
PostPosted: Tue Jul 15, 2025 3:14 am
Hmmmm...
PostPosted: Tue Jul 15, 2025 4:51 pm
I've made a theme that resembles default Windows 11 theme, it was fairly easy, but only for dock, as theming context menu is so cumbersome. I'm getting lost with all these properties in winstep theme config file.
PostPosted: Wed Jul 16, 2025 1:05 am
Hmmmm...
Ugh!
PostPosted: Mon Jul 21, 2025 4:43 am
I'm no "Linux apologist" at all - Linux advocate, certainly.
That, then. :D
If that optional setting doesn't involve much work then fine, but how many macOS users are switching to Windblows?
Well, at least one that we know of :lol:
Hi, Bumping this request to launch apps (or just activate the mouseover effect) even when the mouse pointer is not 100% exactly inside the dock.
Perhaps with a pixel distance slider allowing to trigger the mouseover effects or lauch apps when the mouse pointer is still outside the dock but within that pixel range sorrounding the dock?
P.S. Loving Nexus Dock so far. It's obviously a labour of love and it shows. Thank you :)
PostPosted: Mon Jul 21, 2025 4:13 pm
Hi, don't want to be snarky, but I'm just curious - when do you expect to release new version?
PostPosted: Mon Jul 21, 2025 7:22 pm
Soooon... :lol: ASAP or rather, I expect ASAIR - as soon as it's ready. :P
PostPosted: Sun Aug 31, 2025 11:41 am
Minor request. It's no big deal but would be nice.
A simple wallpaper rotation with choices of timer for the active theme (different per theme/saved) where user can create a folder and simply a browse to folder pointer where all wallpapers of valid format will change on whatever timer they have set - e.g. 15secs, 30secs. 1min 5min, 10min, 15min, 1hour. 6hrs, 12hrs, 1 day, 1 week.... Random or in sequence alphabetically...etc..
Yes, I know I can do most of that in Windows itself. I just like customization and the fact that everything else is self-contained.
As I suggested, it's very minor but it would be nice instead of the extra steps invoking the O/S instead of only one step set once inside the Winstep app. You could lock it for all or without "Lock wallpaper "selected, user can have a different rotation per-theme, should they select rotation only.
Some theme skinners might decide to create a few custom wallpapers they could include as well in a folder. Just a thought and reiterating, it's no big deal. I guess you could go further with a custom file and module, but I was thinking simpler.
PostPosted: Sun Aug 31, 2025 1:16 pm
As you stated, it is already in the OS. Adding something like this would not only be redundant as it would conflict with the Windows slideshow feature (not to mention MS has made some recent changes that apparently broke some 3rd party wallpaper changers).
No way I want to open that can of worms! :D
But thanks for the suggestion anyway. :)
PostPosted: Sun Aug 31, 2025 4:15 pm
Oh no, definitely no more worms please! :D (In cans or otherwise!) And that's just with Win 11. I'm discovering quite a few probs even with Win 10 (more on which as and when I can find the time. :( ) And let's bear in mind, the real Pandora's Box of Win 12 is still to come. So, the fewer cans of worms for now the better, surely.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 1055 posts ] Go to page Previous  1 ... 59, 60, 61, 62, 63, 64, 65 ... 71  Next
Users browsing this forum: Amazon [Bot], Google [Bot] and 168 guests
