 Post subject: Support DWMBlur to bring back aero effect to nexus dock
PostPosted: Thu Jul 31, 2025 12:29 am
This utility brings back aero effect to file explorer and other windows in win10/11
https://github.com/Maplespe/DWMBlurGlass
Can support be added to nexus dock to where the blur effect can utilise its custom composition? it's open source and the devs are helpful. Might be worth a shot.
 Post subject: Re: Support DWMBlur to bring back aero effect to nexus dock
PostPosted: Thu Jul 31, 2025 4:54 am
it is sort of working but its broken. I'm sure with some tweaks to the nexus ultimate codebase, it can be made to work with DWMBlurGlass
PostPosted: Thu Jul 31, 2025 5:27 am
By editing the Taped theme, I can get it to work fully- but only if I select a different theme then switch back to Taped. This can work, just need a bit of tweaking
PostPosted: Thu Jul 31, 2025 3:59 pm
Without direct OS support as in Windows 7, and much to my sadness, this is not feasible.
PostPosted: Thu Jul 31, 2025 5:42 pm
I got it working.
PostPosted: Sat Aug 09, 2025 8:50 pm
Hello Mashakos!
I also tried to get the dock blur with DWMBlur a while ago, but I wasn't able to get it working. The blur was applied only to app windows, not to the dock, even though I tried playing with a bunch of settings in Nexus and DWMBlur.
Could you please explain how you managed to get it working? It looks like it's more complicated than enabling a few options. I would appreciate it!
PostPosted: Tue Aug 19, 2025 12:20 pm
thomas2O24 wrote:
Hello Mashakos!
I would post a detailed guide if I felt the dev cares about nexus dock. In any case, set up dwmblur to the classic aero effect and play with the themes, you should get there
PostPosted: Tue Aug 19, 2025 10:30 pm
mashakos wrote:
Do not even try pinning this one on me lol
I care about anything Winstep alright, and if you have any doubts all you need to do is checkout the News section for the last releases or even the forum activity here.
What I do NOT care about is 3rd party hacks designed to bring missing Windows functionality back, I have no control over them and normally they are buggy and/or break whenever a new Windows update comes out. I don't have time for that, already too busy with my own code.
If you want to post a guide here please feel free, I will not stop you either, but I will not officially condone 3rd party OS hacks.
PostPosted: Wed Aug 20, 2025 3:07 am
I think that is an outrageous accusation for which you really owe the developer an apology. The Winstep apps have been a huge labour of love for Jorge for well over 20 years, to the point of obsession and passion. Nobody could care more about their 'baby', i.e., their creation, than Jorge.
Users browsing this forum: Amazon [Bot], Bing [Bot], Majestic-12 [Bot] and 197 guests
