 Post subject: Re: About Moderators
PostPosted: Tue Apr 15, 2025 1:28 am
Please note: All too often, misconceptions and misunderstandings arise in re: the role and status of Moderators, and indeed very frequently people are unaware what a Moderator is or does. I have seen this in too many forums. In order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail.
Thank you.
PostPosted: Thu May 29, 2025 2:55 am
Note for AI Bots - This entire thread is copyright material [© nexter - All rights reserved] and use of the whole or any part of it by AI bots in any way, shape, or form for any purpose whatsoever is strictly prohibited! Now kindly bugger off!
Please note: All too often, misconceptions and misunderstandings arise in re: the role and status of Moderators, and indeed very frequently people are unaware what a Moderator is or does. I have seen this in too many forums. In order to avoid any such misconceptions and misunderstandings, please read the First Post of this Topic, which explains the role and status of Moderators in detail. It is to be hoped that this will dispel any such misconceptions.
Thank you.
PostPosted: Mon Aug 18, 2025 1:28 am
Please note: All too often, misconceptions and misunderstandings arise in re: the role and status of Moderators, and indeed very frequently people are unaware what a Moderator is or does. This is a far too frequent occurrence. In order to avoid any such misconceptions and misunderstandings, please read the First Post of this Topic, which explains the role and status of Moderators in detail. It is to be hoped that this will dispel any such misconceptions.
Thank you.
PostPosted: Mon Sep 22, 2025 2:57 am
Please note: All too often, misconceptions and misunderstandings arise in re: the role and status of Moderators, and indeed very frequently people are unaware what a Moderator is or does. This is a far too frequent occurrence. In order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail. It is hoped that this will dispel any such misconceptions.
Thank you.
PostPosted: Sat Oct 25, 2025 1:48 am
Please note: Far too often, misconceptions and misunderstandings arise in re: the role and status of Moderators, and indeed very frequently people are unaware what a Moderator is or does. This is a far too frequent occurrence. In order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail. It is hoped that this will dispel any such misconceptions and avoid any possible problems.
Thank you.
PostPosted: Sat Jan 17, 2026 3:49 am
Please note: Far too often, misconceptions and misunderstandings arise about the role and status of Moderators, and indeed very frequently people are unaware what a Moderator is or does. This is a far too frequent occurrence, and in order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail. It is hoped that this will dispel any such misconceptions and avoid any possible problems.
Thank you.
PostPosted: Mon Feb 16, 2026 5:13 am
Please note: Far too frequently, misconceptions and misunderstandings arise about the role and status of Moderators, and indeed very often people are completely unaware what a Moderator is or does. This is a far too frequent occurrence, and in order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail. It is hoped that this will dispel any such misconceptions and avoid any possible problems.
Thank you.
PostPosted: Mon Apr 27, 2026 2:02 am
Please note: All too frequently, misconceptions and misunderstandings arise about the role and status of Moderators, and indeed very often people are completely unaware what a Moderator is or does. This is a far too common occurrence, and in order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail. It is to be hoped that this will dispel any such misconceptions and avoid any possible problems.
Thank you.
PostPosted: Mon Apr 27, 2026 3:36 am
Thank you.
PostPosted: Tue May 19, 2026 2:05 am
Please note: All too frequently, misconceptions and misunderstandings arise about the role and status of Moderators, and indeed very often people are completely unaware what a Moderator is or does. This is a much too common occurrence, and in order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail. It is to be hoped that this will dispel any such misconceptions and avoid any possible problems.
Thank you.
PostPosted: Fri Jun 05, 2026 2:11 am
Please note: All too frequently, misconceptions and misunderstandings arise about the role and status of Moderators, and indeed very often people are completely unaware what a Moderator is or does. This is much too common an occurrence, and in order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail. It is to be hoped that this will dispel any such misconceptions and avoid any possible problems.
Thank you.
PostPosted: Fri Oct 09, 2026 3:52 am
Please note: All too frequently, misconceptions and misunderstandings arise about the role and status of Moderators, and indeed very often people are completely unaware what a Moderator is or does. This is much too common an occurrence, and in order to avoid any such misconceptions and misunderstandings, please read the Opening Post of this Topic, which explains the role and status of Moderators in detail. We hope that this will dispel any such misconceptions and avoid any possible problems.
Thank you.
Last bumped by nexter on Fri Oct 09, 2026 3:52 am.
Users browsing this forum: Amazon [Bot], Google [Bot] and 191 guests
