 Post subject: Recycler Does Not Refresh the Status of Win11 Recycle Bin
PostPosted: Thu Sep 11, 2025 2:22 pm
When sending files to, or emptying the recycle bin in Windows 11, the Recycler has begun to not Indicate the current status. It currently just shows empty.
File comment: Current status
 Post subject: Re: Recycler Does Not Refresh the Status of Win11 Recycle Bi
PostPosted: Thu Sep 11, 2025 3:12 pm
Still working fine here in 24H2.
What version of Nexus, what version of Windows 11? Is it an Insider version?
When you say "has begun" it means it was working previously. What did you change in your system from then to now?
PostPosted: Thu Sep 11, 2025 5:57 pm
Sorry for the lack of information. Has worked with 24H2 previously. I just updated my Nexus registration In August I G7p6wnR2ZzBm8V@.
PostPosted: Thu Sep 11, 2025 6:43 pm
You are still running the Preview of the latest Windows update. Install the official Tuesday 9th update and let me know if that fixes the issue.
Also, under
do you see a wintep.exe file?
PostPosted: Thu Sep 11, 2025 7:49 pm
After todays Windows update Nexus appears to be working fine again. Thank you.
PostPosted: Thu Sep 11, 2025 7:50 pm
Thanks for letting me know. All is well when it ends well.
Users browsing this forum: Amazon [Bot], Bing [Bot], Majestic-12 [Bot] and 197 guests
