 Post subject: Re: Access Violation
PostPosted: Sat Sep 13, 2025 8:30 am
About the backup files, i upload the file at here but it said extension wbk is not allowed
PostPosted: Sat Sep 13, 2025 9:17 am
Send it by email to the Winstep support address please.
PostPosted: Sun Sep 14, 2025 11:24 am
WQinzZ wrote:
Hi, im using the latest version, and following the src step,it came out this
and still didnt fix it, i still have to keep pressing retry
I am not trying to throw anything else into the mix but that DISM message is quite concerning, disturbing actually.
OK SFC scans installed files and looks for any corruptions which is why you run it first.
DISM bases its entire repair on (in this command line case) an Online Windows image to repair. If it says it cannot find it - I do not even want to trouble you - First things first - Let Jorge see if there is a fix from his end then go to Microsoft.
PostPosted: Thu Sep 18, 2025 2:52 am
Sent
PostPosted: Thu Sep 18, 2025 2:53 am
About BassDudeNz, i dont quite understand what should i need to do
PostPosted: Thu Sep 18, 2025 4:34 am
WQinzZ wrote:
Sent
Got it, please give me some time to have a look at it...
PostPosted: Sun Sep 21, 2025 5:07 am
Still not done?
PostPosted: Sun Sep 21, 2025 11:59 am
Apologies, been busy with other stuff.
I just tried your backup file here.
This *might* be related to items on the dock pointing to shortcuts (.lnk) files (e.g. Canva.lnk). Since I don't have those shortcuts here I cannot be sure.
What I find strange is you having items in the dock pointing to the original source shortcuts (original .lnk files) rather than the target file itself. I'm saying this because if you drag & drop a shortcut from, say, the Windows Start Menu into the dock, Nexus will normally resolve the shortcut first so that the dock item points to the target file rather than the shortcut itself.
Although this is what should happen, you have a bunch of shortcut items in the dock (e.g. Canvas.lnk, Dev-C++.lnk, Steam.lnk, EA.lnk). I find this rather concerning.
Since you already have a backup, try removing all the items pointing to shortcuts (e.g. .lnk files) from the dock, and see if that solves the Access Violation error at startup). Then try dragging them from the Windows Start Menu into the dock again - see if the shortcuts are properly resolved this time. Either way, please let me know.
Also, what language is your version of Windows?
PostPosted: Sun Sep 21, 2025 11:22 pm
im not quite understand what u want me to do, about the point thing do u mean by removing all the shortcut from the dock?
this is my language version of windows
File comment: and this is my language version of windows
PostPosted: Sun Sep 21, 2025 11:33 pm
I'm not sure how to explain it better.
Is this a language barrier problem (e.g. are you Chinese having a hard time understanding the English language) ? Or you just don't understand my instructions?
If you are Chinese, is your Windows version in Chinese (it doesn't seem to be, however) or English?
PostPosted: Mon Sep 22, 2025 10:57 am
my window language is english and yea i dont quite understand the instruction. I'll try to remove all the shortcut, restart laptop and add again to see if the error gone
PostPosted: Mon Sep 22, 2025 11:14 am
After i remove all the shorcut and restart my laptop. The nexus still show me the same thing.
Users browsing this forum: Bing [Bot], Google [Bot] and 187 guests
