Board index : Winstep Forums : General Discussion  [ 18 posts ] Go to page Previous  1, 2
 Post subject: Re: placer la barre sur l'écran de son choix ne fonctionne p
PostPosted: Tue Oct 07, 2025 12:26 pm
danimusicos wrote:
Hello, last night I turned off monitors 2 and 3, with the first one in sleep mode. This morning, when turning everything back on, the dock defaulted to the first monitor. I switched it back to number 2, even though it was already set that way in the settings.
The dock will always default to the only visible monitor if you turn the other monitors off... this is by design so it doesn't become inaccessible because it is positioned outside the visible coordinate space.
It should have returned to monitor 2 when you turned the other two monitors back on the following morning, assuming multi-monitor profiles are enabled. Perhaps you disabled them while experimenting previously?
Go to Preferences -> General tab -> Make sure "Disable multi-monitor profiles' at the bottom left is NOT checked.
danimusicos wrote:
Licenses are too much for me now that I only have 2 PCs left! Otherwise I’ll put a free version of Nexus, and on my main PC I’ll use Ultimate with a subscription.
If you only have two PCs and both are for personal use, just use Nexus Ultimate with the same single user license on both PCs, with my personal blessing.
PostPosted: Tue Oct 07, 2025 7:45 pm
bonsoir, j'avais essayé ce matin de tester nexus ultimate sur mon autre disque que se trouve sur le même pc. Et quand je suis revenu sur ma config normale j'ai eu ce message. J'ai compris que j'avais omis de désinstaller en quittant de l'autre disque d'essai ce que j'ai fait ce soir, mais le message revient et je ne peux pas tester tout est bloqué. Salutations.
PostPosted: Tue Oct 07, 2025 9:24 pm
That's part of the protection mechanism.
You need either to register Nexus Ultimate or wait until tomorrow (i.e. try again tomorrow).
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 18 posts ] Go to page Previous  1, 2
Users browsing this forum: Amazon [Bot], Google [Bot] and 186 guests
