Board index : Winstep Forums : General Discussion  [ 838 posts ] Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 56  Next
PostPosted: Sun Nov 09, 2025 3:41 am
Now all the decade+ older themes are finished. I cleaned a lot of this up. It's a little busy, but I still like it even after all of this time.
As for Political Correctness (P.C)... honestly, I could not care less. It's about what it represents, a hub of almost all things artistic.
Stuff the tyranny of PC-ism! (I'm not having any of it and will never use "Newspeak"!) Besides, I don't even see where it might possibly be relevant to the theme?
Da Vinci's Last Supper is located in the refectory of the Convent of Santa Maria delle Grazie in Milan, Italy - Unfortunately, I found that out after-the-fact :lol:
Well, it couldn't really be in the louvre, but so what? I'm pretty sure the the man and Dog near-touch is in the Sistine Chapel, IIRC? You could always call the theme something like "Art Fan". :)
PostPosted: Sun Nov 09, 2025 12:41 pm
You're probably correct though the Louvre Pyramid is a dead giveaway :lol:
PostPosted: Sun Nov 09, 2025 3:33 pm
Meters - Took me a while to get the hang of some meter settings, but I understand the gist of it in all of them properly now.
The CPU graph was an idea borrowed from the Winstep 7 Xtreme theme, quite easy to create actually as soon as I looked at it closely - Create a square black bg, create a transparent grey tic-tac-toe graph over the top, group, paste inside a circle, add an Adobe light spotlight and boom, instant 3D illusion. All of 5mins. I should add I am not trying to be a smartass - I have been doing these themes solidly daily almost for a few months, so like anyone, the more you do something, the quicker you become.
This is a futuristic-based theme which was my original intent and I worked on the wallpaper idea for some time. I finally settled on destroyed aircraft engines and other paraphernalia that no longer worked to get to this which is finished and the wallpaper comes with it. I've spent enough time on it. the oxymoron is that electromagnetic radiation will destroy every combustible, electronic and electric machine on the planet so none of what is here would actually work at all.
Anyone who has seen a post apocalyptic environment, it always seems to be red, fires or brown. While sure, there will probably be fires, after a period the air will go a completely different set of colors if you know your chemistry. Movies and fiction books are just that - fiction.
PostPosted: Mon Nov 10, 2025 10:33 am
FULL TESTING COMPLETED:
I have tested and made adjustments accordingly.
Only ONE thing does not and probably never will work as anyone might like. It is the only thing in the "CONS"
PROS:
1. All menus by default scale as is from resolutions of 1920x1080 to 5120x1440 (Ultra-widescreen - 48" curved monitors included). Adjusting DPI inside the Winstep app is up to personal taste.
2. All modules scale as created from resolutions of 1920x1080 to 5120x1440 (Ultra-widescreen - 48" curved monitors included). Adjusting Module scaling inside the Winstep app is up to personal taste.
CONS:
All Wallpapers were created in Hi-resolution and redone if they were not - HOWEVER - There is no way any 16:9 or 16:10 High resolution wallpaper will look right on an Ultra-Widescreen monitor. The wallpapers will work beautifully in any 16:9 and 16:10 4K monitor (or Smart TV - yes tested that too) - It's unrealistic to expect a wallpaper to lose half of its height nearly and widen by nearly double, and then look the same.
LAST:
ALL Themes were taken offline because I tested all of them (Screenshot below), and fixed where needed, and/or made adjustments. I will upload ALL of them starting soon in the coming week(s). It was a fair bit of work.
Apologies to anyone who has already downloaded some, sincerely. This is about my own personal standards of my own work. I apologise for any inconvenience but I won't apologise for my own standards.
Laterz...
THEMES COMING (5120x1440 view - no, they do not look that small): -48 Themes in all. Only two themes are not mine.
PostPosted: Mon Nov 10, 2025 4:36 pm
Well, that doesn't necessarily imply all the art works have to be from the Louvre... :)
PostPosted: Tue Nov 11, 2025 6:21 pm
Insight into testing.
Have been doing this with 48 themes. This is why reuploading hasn't been immediate.
So far every theme with only wallpaper exceptions here and there which I can live with, seem to work.
Don't be fooled by the fact that the 5120 seems small with menus and modules. It isn't. The forum default view scales it down. If in doubt, click it and zoom in.
PostPosted: Wed Nov 12, 2025 7:42 pm
It is what it is, I mentioned it much earlier and never posted. Just finished editing readying for upload. Also - With different astrological signs (tested in several themes all working). The wallpaper is self-created and they all go in correct cycles clockwise with both a master chart and sky star patterns overlaid on top.
PostPosted: Thu Nov 13, 2025 11:36 am
Took a break today between fixing the others and created this. Almost done, just the tiny default Workshelf hide/close/open/Mouseover etc to do.
It is impossible to include everything, the Grand Canyon, Eiffel Tower and more are not here... and equally deserving of wonder.
There are now debates on what is a world wonder FFS. For a start there are the ancient wonders which number seven, there were more attributed this title and now they are trying to dispel some that are truly amazing testaments to humankind's ingenuity. Are they amazing to look at? Yes. Therefore most people gaze in 'Wonder'.. they're Wonders... stupid humans.
PostPosted: Thu Nov 13, 2025 8:47 pm
There's a lot of room here for controversy and debate, and I'm going to have to bite. :) First, linguistics - "humankind" is not in my desk edition of the OED c.1980, it's a just PC "Newspeak", the proper term is still mankind in my book.
Then, the whole concept of "Wonders of the World" and their definitions and selections are highly debatable, at least for the modern world. As far as the 7 ancient ones are concerned, they were of their time and pretty much defined by the Ancient Greeks and their limited world view. The modern ones are largely defined by a western world view, which makes them all the more debatable.
Of the ones that occur here, there are two abominations to start with. Mount Rushmore is just about the ugliest, most vulgar and most pompous abomination ever inflicted upon nature. Sheer vandalism One can only hope that an earthquake or similarly destructive natural disaster destroys this utterly. And the Sydney Opera House - an abomination of modern architecture of the highest order, if ever there was one. (Granted, there are a lot of others all over the planet!) Stomach churning stuff really.
The Leaning Tower of Pisa is no more than a curiosity, an accident of subsidence due to poor choice of location.
The Hagya Sophia really is by far surpassed by the Blue Mosque, aka the Mosque of Suleiman the Lawmaker, a truly outstanding work of beauty both inside and out. But one could also argue in favour of one or even two mosques in Syria, or Iran, especially in Mashad.
There's much in Asia that could or should be there, especially in Iran, India, and China. There also is a lot more in Turkey, in Istanbul and also Anatolia. One could go on and on really. Then there are natural phenomena, and scenery. Well, there are spectacular examples almost all over the planet. One could argue about those till the cows come home and go back out again! ;)
Overall, there's also too much of a mix of ancient and more recent. Would have been better to stick to the one or the other IMO.
PostPosted: Fri Nov 14, 2025 12:17 am
Thanks for your feedback.
I chose ones I like.
for me personally, if it is a wonder of architecture and creation then it's a wonder.
As I may have mentioned, the "This isn't a wonder" means anyone could make it. I know I certainly could not.
If I wished to get to the non-human aspects then sure a lot will disappear. The reason I say this is that if mankind made it, then it isn't a wonder based on that? This includes Hagia Sophia, Colossus and Zeus Statues and anything man put his hands on.
It basically has to be a miracle of non-human creation to be called a wonder. If you do that then you won't even have seven.
This is also why I called it "World Wonders", not Wonders of the World. There are only seven ancient Wonders of the World as you well know.
PostPosted: Fri Nov 14, 2025 2:23 pm
First three have been uploaded... I'll just do from now on.
I will be using a common descriptor.
If people like the way it looks/feels, then they'll download it. If they wish to know my motives behind any themes they can ask, but there's enough info in the descriptor.
Nonetheless, what I have written will be universal for all. The last line will be the only one that will change if it is not pertinent to the theme.
PostPosted: Sat Nov 15, 2025 12:07 pm
:lol: :lol: :lol: :lol: :lol:
"You can only upload 20 themes per day"...
So I have more than 40 to reupload... so it will be a few days it doth seem...
85% have Ultrawidescreen wallpapers upscaled mostly extremely well in their own subfolder. The instructions are in the readable download details, so if you cannot read or decide not to, sorry I cannot be of more use.
:oops: :P :lol:
PostPosted: Sat Nov 15, 2025 12:36 pm
Yes, that is the limit to prevent abuse, and I'm glad it's working. :D
Normally it would be much less, but it is set at 20 since the Gallery hasn't opened yet lol
PostPosted: Sun Nov 16, 2025 5:49 pm
I am not sure how the timer works so I will wait for a day in-between uploads because I received the same message again. This means end of this current week to finish which is fine by me. :D
PostPosted: Mon Nov 17, 2025 10:19 am
40 THEMES UPLOADED
Ok - seven to go and this below is my last for a little while as part of the above seven which will be when my timer resets.
Regards.
and the widescreen
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 838 posts ] Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 56  Next
Users browsing this forum: Amazon [Bot], Google [Bot] and 195 guests
