Nezbit wrote:
I would like to see an option to change the font for the data below the drive. I am using it on a 24" HD monitor and I have to make it larger than I would like to easily read the data. I also think showing data on the top and bottom would look too cluttered.
Changing the font would not help, that is already as readable as it can be. As for data on top and bottom, it does look cluttered, but it is really up to the user. By default data is only shown at the bottom of the icon.
Nezbit wrote:
Two of my four drives could not show the Lifetime Remaining, but that is an option I would not use anyway. They were a Western Digital mechanical drive and a Crucial SSD.
Thanks! Mechanical drives (HDDs) do not have "Lifetime Remaining", that is only for SSDs. As for the Crucial, some drives either do not expose some data (I have a T-Force SATA SSD that does not report temperature, they did it deliberately) or they do it in a proprietary way that the disk meter module cannot read (supporting proprietary protocols is completely beyond the scope of this module).
Nezbit wrote:
For the Disk Meter Desktop Module I like the iFlip Calendar slightly better than the iStat. It would depend on what theme I was using though. Having both to choose from would be nice. A light and dark version would also be nice. My eyes are too old to look at small text, so the more readable the better.
Actually it's going to be neither... well, more like the iFlip. Still working on it, but here is what it will look like with room for 3 drives:
techlobo wrote:
When you first open the v25.12 beta zip file, the Readme.txt file specifies it as 25.11 update
You really dig into the details, I like that.
I noticed afterwards, but since it was not a big deal and I had already uploaded the file I did not bother to fix it.
techlobo wrote:
a) Select 'New Preset' in Presets: drop down - nothing happens and the selections reverts to Default.
Ok, I understand it can be a bit confusing at first, but here is how it works:
"New Preset" is anything combination of color settings (Hue, Sat, Lum, Colorize) that is not part of existing Presets. So, whenever you make a change to the existing preset combinations, the combo box changes to "New Preset".
The somewhat confusing part is that you can also select "New Preset" in the combo box. However, if you did not make any changes to the existing settings and those match an existing preset, the existing preset is automatically selected instead.
"New Preset" is also what allows you to know at a glance that the current combination of settings (Hue + Sat + Lum + Colorize) are not saved anywhere and do not match any of the existing presets. You can then save that combination of settings into a new preset by clicking the Save button and naming the new preset.
techlobo wrote:
which I’m not sure what they are meant to represent
Anyone a bit familiar with Photoshop will recognize those settings as they are exactly the same. Those who do not, can simply play with them - there is no room in that dialog (or even on a tooltip) to explain color theory.
techlobo wrote:
I assume that this relates to my current lack of understanding of what colorize means, and hence why one changes to the full range (360) while the other only changes to 100.
Yes... Colorize overlays a "tint" color over a bitmap (that color is defined by the 360º color wheel represented by Hue, it's "intensity" by Saturation and how bright it is by Luminance). When Colorize is not selected, however, a different formula is applied and instead of an absolute color applied to the whole bitmap, ALL the different colors in that bitmap are shifted in Hue by the amount you define with the Hue slider - which is why it now goes from -180 to +180 instead of 0 - 360).
techlobo wrote:
Is this supposed to happen?
Yes. If you make some changes, do not save them as a preset, then go back to that dialog and select an existing preset, this still gives you a chance to go back to the previous combination of settings that were not saved anywhere.
techlobo wrote:
f) However, if I make a change and then save again with the same name, I get a dialog box stating that 'A preset with this name already exists. Do you want to overwrite it?'. If I select Yes, the [b]item is repeated in the drop-down list, not overwritten
Fixed, thanks!
techlobo wrote:
g) I also note that the Presets are just presented in the order saved, not alphabetically which I suspect would make it easier to find if you have a few. Although I appreciate that you would need to retain the ‘system presets’ at the top.
Yep, system presets need to be at the top... in fact, there should be a fake entry saying "--user presets--" separating the two sections.
Also, not sure about being easier to find if stored alphabetically, I suspect there won't be many plus like this they are in chronological order.
techlobo wrote:
i) Am unable to type in Preset: box to select a preset – only option is drop-down selection.
k) Am unable to edit a previously saved preset.
Yes, these are the drawbacks of using a single combo to handle both new and existing presets. But it was required, space is tight.
techlobo wrote:
choose same location / name I get dialog boxes to state that it already exists and do I want to replace it, then on selecting Yes another dialog box (this time from Workshelf) saying it already exists.
Completely forgot the Windows Browse dialog already did a "file already exists with the same name" check for me. Fixed. Also, now I give the default png filename the same name that is on the Presets box (the file is actually being replaced, I checked, and an error dialog now pops up if the application cannot overwrite the file for whatever reason).
techlobo wrote:
Is it not possible to just keep the smaller text for all options?
It is, but then it is even more difficult to read the text at smaller icon sizes (and the current size is the same as that used in all the other modules, e.g. weather, CPU meter, etc. At these sizes it is basically impossible not to overlap a bit of the icon image). You want smaller text, Nezbit wants larger text.
techlobo wrote:
Question[/u] – would it be possible to get the text to display in the same colour as the selected metric i.e. to act as a visual key?
Not really. I think since it is the user who chooses which information goes where, he will know (should know?) what each value refers to.
techlobo wrote:
it would be useful to be able to modify the brightness of the activity display (and possibly the size in the case of the ring / circle representation) – as it is not necessarily obvious.
Actually the led has 3 levels of brightness, depending on how much data is being written/read. But I agree that the lowest level of brightness needs to be more bright.
Anyway, thanks for the detailed observations and the time you spent writing them.
