Board index : Winstep Forums : General Discussion  [ 362 posts ] Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 25  Next
PostPosted: Fri Dec 19, 2025 12:11 pm
New betas of v25.12 are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
This is a beta and MUST be installed ON TOP of a full v25.9 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
Ok, so this one features the destkop version of the new disk meter module.
BassdudeNZ, I know you want it, but you will have to wait a little bit more before being able to skin the desktop version of the new module. Still working on the settings that will be exposed.
If you are curious about the new Show Disk Meter Status in the Troubleshooting Options dialog, the first date/time shows when an attempt to get SMART data was made, the second the time it succeeded (if it did get data) and at the end you have a diag code.
I think the multiple posts I left here already describe what you can do with the module, so have fun playing with it and let me know if you run into any issues please.
Colorization of the desktop module is via the colorization options in the Modules tab of Preferences (click the down arrow below the desktop module preview). Since the light and dark versions of the module are basically grayscale, most colorization options will work well with it (there is a lot of work behind ensuring that is so, too).
I also added the old baby blue ring charts to the \Winstep\Icons\Samples\ folder. You can use those to test or play with the "Change Icon" feature, for instance.
Ah, also, the desktop module can already be attached to the NextSTART taskbar.
This thing has been optimized to hell... for instance, rather than updating the whole desktop module every refresh (which would normally be once per second - or 10 times per second if led activity is enabled), the module is only refreshed if there have been changes, and then only the sections holding the drives that actually need updating (and if we are only dealing with a change in the activity led, only the icon area is updated).
Likewise for a ton of functions under the hood, so please let me know how this handles in terms of performance.
Right now WorkShelf is using less than 0.3% of CPU here, and most of the time doesn't even appear in my CPU meter - and I am showing all 10 of my drives plus all the other modules, etc. This proves performance is more than ok, but from time to time WorkShelf will start using 1.4% or more of CPU for no apparent or valid reason and will stay that way for a prolonged amount of time - still haven't been able to figure out why other than a suspicion that this happens because the WorkShelf process is handed over to an Efficient core in my 12900K rather than remaining in a Performance core.
PostPosted: Fri Dec 19, 2025 1:07 pm
Jorge, perhaps you missed my previous comment? I am patient. As I mentioned earlier, leave until the next update. You have done a lot of work !! That's more than enough. Rome wasn't built in a day as the saying goes...
Thanks for all the hard work Jorge. :)
PostPosted: Fri Dec 19, 2025 4:25 pm
The new Disk Meter Module is great. No change in system performance with four drives.
I would love to see someone create an Xtreme Theme to match the module, both dark and light versions. BassdudeNZ or Picco14 are you busy?
PostPosted: Fri Dec 19, 2025 6:01 pm
I am up for it. I'll wait for the official release though if that is ok with you? :)
Keep in mind it will be only for Nexus / Ultimate in the interim though which won't be much and not what I think you are looking for at all.
The desktop modules are at least one beta away I think? something like that, maybe two?
This means for skinning that is - For Picco14 or me to do a theme/module in Winstep Xtreme, Jorge will need to send us an *.ini type file and a name for the disk module with some base instructions. He mentioned above that is a little way yet. e.g. The calendar is a *.wsi file. I'll need to know what the extension of the Disk file is and what it contains as in what I can display, or change, or not change, or if I can position it differently, or not, how it lays out, sizing and a pile of other things. I believe this is why it is a little time to come yet :)
I could very easily turn the background to match the theme below which I recently uploaded, but the other thing is the color settings you see in this with the circular disks do not save when I change themes, so anything we do at this stage would be wasted until color settings per theme can be saved, which may well be something we need to do in the file for the module. We'll also need a file name for the PNG file too e.g. wsDD.png so we know what to save as.
@Jorge, actually the disk meter would be a good thing to exclude from the free version of Nexus in my opinion. It means it is another reason for people to buy it.
PostPosted: Fri Dec 19, 2025 8:25 pm
No more new modules have been added to the free version of Nexus since Wanda (in fact very little has been added in terms of new features). Battery, Calendar, Moon and now the Disk Meter module are all exclusive to the paid versions.
PostPosted: Fri Dec 19, 2025 9:25 pm
PostPosted: Sun Dec 21, 2025 10:09 am
Ok, this post is more about me trying to organize my thoughts regarding how to skin this new module than anything else.
So, this module has a few distinctive features in relation to all the others: first it grows dynamically (accordingly to the number of drives it is displaying) which means the main bitmap needs stretchable and non stretchable zones defined, plus "padding/offset" values (that support negative numbers) for the start of the sections (this is how I make the default disk meter module).
Second, it is a composite of an external "container" bitmap and multiple internal "section" bitmaps. Each section is exactly the same as the next one, the only thing that changes is its position in relation to the parent container. Thus, any text, icon and graphic coordinates are relative not to the container bitmap but to the section bitmap (and the application itself takes care of converting these relative coordinates to absolute coordinates).
Third, it can be either horizontal or vertical (and because of the text information and histogram graphics, this is not a simple matter of automatically rotating the bitmaps and coordinates 90º clockwise). So, to all effects and purposes, it is as if the vertical version of the module is a different module from the horizontal version, and I think that is how I am going to handle it.
So, I think the solution is to use two different configuration files, one for the horizontal version of the disk meter module, and another for the vertical version. To the skinner, it is basically the same and probably even less confusing that doing both versions in the same configuration file.
The problem is how I integrate this into the application, but I'll figure it out now that I decided how to deal with it (and thanks for listening to my inner monologue, you guys have been a great help in figuring this out :D )
P.S. And in the end I might go with something completely different lol
PostPosted: Tue Dec 23, 2025 7:17 pm
Which is exactly what ended up happening lol Rejoice BassDudeNZ, nearly there! :D
I also optimized the heck of the multimedia timer DLL used to control effect animations to the millisecond... it was kind of my last ditch effort to resolve WorkShelf/Nexus sometimes ramping up to using 1.3% of CPU while idle instead of the normal 0.3%.
As anything related to optimization, it helped a bit since the timer now only fires when strictly necessary, but again this did not solve the problem. WorkShelf still goes up to 1.3% CPU utilization on my system and stays there for a while for no apparent reason. I am still unable to determine why, all I know is that it only happens on Windows 11 and not on previous versions of Windows.
I still have the theory that it might be related to Intel Director and Windows placing the WorkShelf process on a E-Core instead of a P-Core on Intel CPUs, but have not been able to prove that yet either. Pretty frustrating. I don't know what else to optimize (and given the really low CPU usage most of the time, I doubt this has anything to do with optimization or is even related to it).
Damn Microsoft!
PostPosted: Thu Dec 25, 2025 9:39 pm
First disk meter external theme, based on the default theme but different...
This is obviously just an example theme that I will upload to the Winstep Gallery, designed to teach skinners how to skin the new disk meter module.
PostPosted: Sat Dec 27, 2025 7:41 pm
New FINAL betas (beta 4) of v25.12 are out:
This beta allows skinning of the new Disk Meter desktop module. An iStat theme for the Disk Meter module was just uploaded to the Winstep Gallery to serve as a tutorial/template on how to skin the new disk meter module.
PostPosted: Sat Dec 27, 2025 9:14 pm
OK a couple of things please.
USER first (not skinner) - Jorge,
1. if the user goes to the trouble of saving a color theme inside the Disk meter which it can and does, just like Workshelf, it REALLY needs to recall when they reload the theme (or switching themes). Defaulting back to your built-in settings when ANY user spends time adjusting hues and colors and then saving them, then on reload it does not recall is extremely annoying.
What it does effectively, is make some, perhaps many if not a majority of users think "Why did I bother saving my settings if I have to click multiple times every time I load a theme just to get my saved settings that never recall????"
2. The ability to show/hide full graphic display - and just disk icon or chart on the module like you can in Nexus.
SKINNER (simple and short)
I have looked all through and experimented one at a time to visually see what each change does. It's going to take a while. I am having issues bringing the full display back since I changed to only icons. I may need to uninstall reinstall the normal version if restoring my backed up settings fails - haven't got there yet. It's probably something I did. Please note, I have the updated Notepad that undoes 99 times so even going back to your default is still not producing anticipated results. As I said, it will take a little while.
Before you ask, yes, the environment variables (absolute paths) are correct inside the file and the file is inside the theme I am testing it in with it renamed to match prefix filename.
The png fixed aspect (so far) makes skinning less fun but I have not got close to exploring all the possibilities so I'll reserve that possibly wrong statement for later.
As a suggestion, many people feel if they see a paragraph of block text that covers two pages, that they run away from it. May I suggest you separate each section in the uploaded module file with a simple space between different sections? - most importantly drives? I have already done it in the one I am working on.
This is why you see on several forums TLDR (Too long didn't read).
It is wonderful you did this and thank you, but the color thing for users, I do not believe you should bypass this lightly.
Hope you had a nice Christmas with the family :)
PostPosted: Sat Dec 27, 2025 10:20 pm
As mentioned, it will take a little while. This is nowhere near right but it is getting there.
Excerpt only. The dimensions are the hardest part as in resizing canvas makes no difference other than mess up the meters. It's a different beast.
I'll get it, practice makes...better :)
PostPosted: Sun Dec 28, 2025 10:28 am
Ok, before anything else, WHY are the disk meter desktop modules in your screenshots displaying N/A for the Read and Write speeds? Did you take those screenshots before the modules started updating those values or is there something actually wrong in there?
I think you are misunderstanding something fundamental: you CANNOT save themes or make changes to existing themes using the Winstep application. Currently the only way to make or change a theme is by editing the config files directly.
When you "save" a new color scheme in the Icon Factory dialog, you are simply saving that color scheme to the User Presets so it can be quickly recalled later - NOT to the current theme.
What this means in practice: because themes override user colorization settings for iconic modules (so the theme maker can, for instance, adjust the colors of histogram graphics for modules like the CPU meter, etc, to better match the theme), when you load a new theme those color/colorization settings either receive their new values from the new theme (IF the theme has explicit settings for that module) OR are reset to default.
If you want a specific theme to always show a specific disk meter colorization whenever you load it, you will have to edit that theme's WSD config file (if it has one, otherwise you can create one) and add the proper values to
DiskDriveColorize=False
DiskDriveHue=0
DiskDriveSat=4
DiskDriveLum=43
DiskBackMeterColorize=False
DiskBackMeterHue=0
DiskBackMeterSat=0
DiskBackMeterLum=0
DiskBlueMeterColorize=False
DiskBlueMeterHue=0
DiskBlueMeterSat=0
DiskBlueMeterLum=0
DiskRedMeterColorize=False
DiskRedMeterHue=0
DiskRedMeterSat=0
DiskRedMeterLum=0
DiskBlueRingColorize=False
DiskBlueRingHue=0
DiskBlueRingSat=0
DiskBlueRingLum=0
DiskOrangeRingColorize=False
DiskOrangeRingHue=0
DiskOrangeRingSat=0
DiskOrangeRingLum=0
If you do this, NOW when you load that theme the disk meter icons will assume whatever color scheme you used for that theme. This is what the iStat theme does and the reason the disk drives always turn white when you load that theme.
The same thing you are complaining about happens with the clock and other modules. For instance, the user can set the color of the digits of the digital clock to blue but if you switch to another theme (one that has no settings for this) it gets reset back to the default green.
What do you mean by "like you can in Nexus" ?!
Also, you mean dynamically disable the histogram disk activity graphics in the desktop module via a USER setting rather than a SKINNER setting? If so, the only thing that could be made to happen is stop the histograms from displaying data, but you cannot recover the space used by them in the desktop module since that is a theme setting.
If, however, you mean as a THEME option, then simply set
DiskGraphEnabled01H, DiskGraphEnabled02H, DiskGraphEnabled01V and DiskGraphEnabled02V to False.
Huh? Right click the desktop module and select "Display as Full Disk Meter"
You mean on the iSat Disk Meter module? It has separating lines between the sections and text areas (if you can't see them perhaps the brightness of your monitor is turned all the way down) AND, anyway, it is intended solely as a simple tutorial theme, not as something you should actually use.
Use the pad values. For instance, for a horizontal module:
Final module width = TileLeft + SectionPadLeft + No of disks * SectionWidth + SectionPadRight + TileRight
Notice how the actual width of the container bitmap is irrelevant here. Want to increase the distance between the end of the last section and the rightmost edge of the container bitmap? Increase the SectionPadRight value (increasing when a number is negative means moving it towards zero; make it a positive value if required).
Reason the pad values are negative in the example theme is to make the start and end of the sections "move" into/inside the main bitmap tiled areas.
Thanks, you too! :D
PostPosted: Sun Dec 28, 2025 12:38 pm
Thanks, you too! :D
Yes I got all that and where I got it all wrong... Thanks :) - I will attempt it better when people stop visiting....it's that time of year... :lol:
PostPosted: Sun Dec 28, 2025 2:29 pm
Sure, would still appreciate a quick reply to this tough, if possible, but I fully understand if not:
Folks, this is going to be a quick beta. It needs to be, as it needs to be released before 2025 turns into 2026 lol. ANY outstanding issues need to be reported ASAP, please!
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 362 posts ] Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 25  Next
Users browsing this forum: Amazon [Bot] and 159 guests
