Board index : Winstep Forums : General Discussion  [ 97 posts ] Go to page 1, 2, 3, 4, 5 ... 7  Next
 Post subject: So, what's next after v26.4 ?
PostPosted: Wed Apr 22, 2026 3:58 am
As I mentioned in previous installments of this series, I’m now mostly focused on tying up loose ends. Part of that effort has involved long‑overdue updates to the website over the past few weeks - reorganizing its structure, improving the flow of the text, and refreshing many of the screenshots to give the software a cleaner, more contemporary look.
With BMT Micro now able to process Chinese payments and a new partnership in place with a Chinese reseller, I also reopened the floodgates to China. The last time I attempted this, the Winstep server was instantly overwhelmed by the sheer volume of update requests pouring in from Chinese users.
I can now confirm that the free version of Nexus has over 280,000 active users in China, with a confident estimate of roughly 400,000 total installations. Because these systems had not been updated in over a year, they all attempted to download the full 40 MB installer instead of the lighter 16 MB update package. Worse, the Winstep Updater’s repeated failures to reach the website - due to the previous firewall block - caused most clients to retry in the same concentrated 10‑minute window. The resulting surge completely locked up the server, and once the real numbers became clear, the reason was obvious. I had no choice but to block China again.
No single bare‑metal server can handle a load of this magnitude, so reopening China required a multi‑pronged solution:
• moving update files to a CDN (Content Delivery Network),
• rewriting the Winstep Update Manager so Chinese downloads are redirected to the CDN instead of the Winstep server, and
• ensuring that future connection failures would not cluster retries into the same narrow time window.
Instead of every request hitting one machine, the load is now distributed globally - which dramatically improves reliability and absorbs traffic spikes.
Once all of that was in place, the final step was to reopen China gradually rather than all at once. The firewall contained 55 separate Chinese IP range blocks, and on the 16th of April I started removing them one by one over the course of 24 hours to control the flow of incoming requests.
As each block was lifted, users in that range immediately downloaded a small 2 MB update to the Winstep Update Manager, which then directed them to retrieve the much larger 40 MB application update from the CDN instead of the Winstep server.
This worked and prevented the Winstep server from becoming overloaded again.
Now I have a different problem: serving hundreds of thousands of updates and more than 10 TB of data through the CDN is not cheap. And while having nearly half a million users in China sounds like a massive opportunity, it’s also a massive liability if it doesn’t translate into revenue.
When I originally developed the free version of Nexus, it had to compete directly with well established docks like ObjectDock and RocketDock. To stand out, I added features that probably should have remained exclusive to the paid editions - and that strategy worked. Nexus became the de facto standard for docks.
But success brings its own challenges: for many users, the free version is already “good enough.”
The “Buy me a beer” toaster I added to the latest free version has produced some results -better than nothing, at least - but overall the response has been discouragingly weak. It’s clear that passive support alone isn’t enough.
Different markets also respond differently, and what works in one region doesn’t necessarily translate to another. As someone put it rather eloquently, relying on love to generate revenue is an inefficient strategy.
That said, I want to be absolutely clear about one thing: I will never remove features from the free version or bundle it with adware. I’ve been approached multiple times over the years with offers to monetize Nexus that way, and I’ve always refused. Reputation takes years to build and seconds to destroy - and that’s not a line I’m ever willing to cross.
So the focus now is on improving how the free version communicates value.
The same person who offered that insight also suggested adding subtle prompts inside the free version when users attempt to access particularly valuable features. We both agree that we shouldn’t push or annoy users; instead, we should guide them toward the version that best fits their needs. Taking it step by step is essential.
Going forward, premium features - such as Create New Dock, Add Grid Stack, and others - rather than being completely absent will now become visible in the interface and in the right click context menus, marked with a small lock icon. Users will naturally discover them as they explore. When they try to access one, the application will provide a clear, contextual explanation along with the option to upgrade.
The goal isn’t to push or annoy, but to guide - helping users understand what’s possible and what they gain by upgrading.
Finally, in terms of actual feature improvements to the applications themselves, I’m convinced that the single change with the greatest impact will be the re-introduction of the Winstep Theme Builder - even for users of the free version.
The Nexus skinning engine supports capabilities no other dock offers, such as overlays and advanced compositing, but right now, most users never fully tap into that power. Giving users a dedicated tool to harness that power - rather than simply copying existing RocketDock skins - changes that completely.
For the first time in years, users will be able to create, customize, and share complete themes without needing external tools, arcane knowledge, or manual file editing. It empowers creative users, lowers the barrier to entry for new designers, and encourages a community‑driven pipeline of fresh content.
A strong theme ecosystem keeps the software visually fresh, reduces support overhead, and naturally drives interest in more advanced features.
In short, the Theme Builder doesn’t just improve the product - it strengthens the entire Winstep platform.
A natural progression from this would be finally opening the Winstep Themes Gallery to the public, but that depends on reaching a level of sustainability where supporting that ecosystem becomes viable.
 Post subject: Re: So, what's next after v26.4 ?
PostPosted: Thu Apr 23, 2026 1:39 am
Excellent plan, that "guiding" linking, Jorge! :D Hope "The Thing that must not be Named" ;) will be comprehensive, not just an initial release for Nexus? Might encourage people to look beyond Nexus...
PostPosted: Fri Apr 24, 2026 1:06 am
Ok, finished adding all 16 different variations of the Upgrade Dialog to the free version of Nexus. It will pop up when the user clicks on a feature that is only available in the paid version(s) and will be contextual to what the user clicked on.
I think I might do a silent update to the free version of Nexus (silent because there aren't really any new features other than a relatively minor bug fix) to see if this actually makes a difference. Need to update the language files first, though..
In the mean time, I really like the new Winstep Xtreme logo:
PostPosted: Fri Apr 24, 2026 1:20 am
More upgrade dialogs... These are contextual upgrade dialogs that explain and showcase the specific premium feature the user just attempted to access.
They use a common layout with shared branding and controls, while the images, descriptions and messaging adapt to the specific premium feature the user just selected. Premium-only features are marked with a padlock icon so users immediately understand they are not available in the free version.
So, I did not remove features from the free version - which would have had a negative impact. Instead, I exposed additional features in the interface so users can discover what exists in the paid versions. These premium-only features remain non-functional until the user upgrades to either Nexus Ultimate or Winstep Xtreme.
The goal is to improve feature discovery and make users aware of the capabilities available in the paid versions. Previously, many users possibly never even realized those features existed at all - and therefore never felt they were missing anything.
PostPosted: Fri Apr 24, 2026 4:20 am
Neat! :D Excellently laid out and good branding Jorge, well done! :D
PostPosted: Fri Apr 24, 2026 8:41 am
Thanks!
Couldn't have done it without the help of the AI, though. It's like working with an assistant, it has made me a lot more productive.
Anyway, changed the button so it mirrors the initial mockup, looks a lot better IMO. Still have to fiddle a bit with the colors.
Unrelated, pisses me off users complaining about the UI looking "outdated". As you can see, I could fix that - but then you would need a 4K monitor just to be able to see all the options at once. Sigh. What a waste of screen space the modern Windows 11 UI is... :roll:
PostPosted: Sat Apr 25, 2026 2:57 am
Again, looking very good. 8) Window border might need a little work? Worried about the use of Big Tech AI - it's all going to be used in further training AI, and goodness knows what else happens to your data. :(
Yeah, sympathise with your view re: users complaining about the UI looking 'dated'. Ridiculous nonsense. I'd tell them get an 8K monitor and I'll deliver... ;) Win 11 is just one big disaster area in all respects. And I dread to think what they come up with with Win 12! :/
PostPosted: Sat Apr 25, 2026 10:17 am
You mean the small "artifacts" around the blue window border? I cropped the image directly from my desktop background, that's what is showing.
PostPosted: Sun Apr 26, 2026 10:23 pm
Oh right, sorry Jorge, my mistake. :D
Gosh, it's bloody quiet in here most of the time these days, innit?
PostPosted: Fri May 01, 2026 2:26 pm
Nexter, I know you are not going to like this, but I had so many people requesting this that I just implemented the ability to extend the background of a dock to full screen width (horizontal docks) or height (vertical docks).
Only for docked docks AND non-tiled docks, of course.
Icons will appear centered in the dock. Wanna bet someone will now ask me to add an option to left and right justify the icons? :D
PostPosted: Sat May 02, 2026 7:14 am
Arrrgh! Ghastly! :twisted: Not like it?! *Hate* it. :P It's an evil thing - hope those who want this burn eternally! ;)
Seriously though, it does go completely against the grain of what a dock is. :(
And yes, I expect someone *will* ask for left and right justifying icons Jorge - preferably both at the same time one supposes. :P
PostPosted: Sun May 03, 2026 7:50 pm
I’m reintroducing the Weather.com feed, but this time only as a fallback in case the MSN feed (after all these years the last working feed with weather forecast) becomes unavailable.
Because Weather.com abandoned their old location codes and now relies exclusively on latitude/longitude identifiers, I’ve had to update the built‑in locations database so many cities now include their coordinates. Many entries still lack this data, but the MSN feed conveniently returns latitude/longitude for any resolved location.
Since MSN is now the primary provider and still accepts Weather.com codes as well as city+country queries, I can use it to retrieve and cache coordinates that the Weather.com backup feed can use if MSN ever goes down.
Additionally, the GEOIP lookup used during first‑run setup of the weather module also provides latitude and longitude, which further helps populate missing coordinate data.
PostPosted: Sun May 03, 2026 11:04 pm
Hmm... I wonder if that will work out all that well, given that an ever increasing number of folks use VPNs and/or TOR network, and thus not necessarily their real location. Plus, like myself, a lot of people cripple all geolocation services in Windblows.
PostPosted: Mon May 04, 2026 12:57 am
GeoIP location isn’t based on any Windows service - it simply uses the user’s WAN IP address.
Naturally, the location will be incorrect if the user is behind a VPN, but this is only meant as a convenience feature so users don’t have to manually configure their weather modules. Previously, the default location was always New York, USA.
Users will also be able to enter latitude and longitude directly, just as they can already do with Weather.com and METAR codes.
PostPosted: Mon May 04, 2026 2:27 pm
Also, it seems Open-Meteo is also a good free backup feed, and they seem to be much friendlier to weather widgets than Weather.com ever was.
Already looking into implementing Open-Meteo as a backup feed to the primary MSN feed.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 97 posts ] Go to page 1, 2, 3, 4, 5 ... 7  Next
Users browsing this forum: Amazon [Bot] and 192 guests
