 Post subject: Add folders or files to a shelf tab
PostPosted: Thu Apr 23, 2026 6:05 pm
Hi,
In windows explorer there is a work shelf context menu in SendTo. I can use this to add a single file or folder to a shelf tab. But, when I select multiple files or folders it is not adding all selected multiple files and folders instead it adds only one file or folder.
How can add multiple files and folders to a work shelf tab using Windows file explorer right click menu?
Also, is there similar feature for Send to Dock or Send to NexStart?
 Post subject: Re: Add folders or files to a shelf tab
PostPosted: Thu Apr 23, 2026 11:56 pm
"Send to" is one of those small "quality of life" improvements. Because of how it works under-the-hood It is only meant to work with a single file - if you want to add multiple files at once, use drag & drop.
For instance, I have Microsoft Notepad in my "Send to" list. If I try to Send To more than a single text file to Notepad, the operation fails.
PostPosted: Mon May 11, 2026 7:20 am
As far as I know the Send To integration only supports single items because of how Windows handles that menu. For multiple files or folders, drag and drop is probably the intended workflow.
fnf game
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 185 guests
