Board index : Winstep Forums : General Discussion  [ 199 posts ] Go to page 1, 2, 3, 4, 5 ... 14  Next
 Post subject: So, what's next after v26.6 ?
PostPosted: Sun Jun 28, 2026 10:04 pm
Adding a complete and detailed User Guide for all Winstep applications in v26.6 was actually something I wasn’t initially expecting to happen. But it did, and it’s another item crossed off the to‑do list.
So, what’s left? As before:
    1. The Theme Builder
    2. Revamp the Winstep Gallery and open it to the public
    3. More multi‑session modules (desktop clock, weather, battery, network monitor)
The v26.6 release also almost went without a glitch. Almost.
Because of what happened to a single user, at the last minute I decided to make sure dock and shelf contents would not be lost in case of a power loss while the Winstep application was busy saving changed data.
Previously, the registry keys holding stale shelf and dock data were deleted first, and then fresh data was written. The problem is that saving hundreds or even thousands of registry entries takes time. If the power goes out in the middle of that process, the data ends up missing or corrupted. That’s exactly what happened to that one user.
To prevent this, data is now written to a temporary registry key first. Only after all data has been successfully written is the permanent key deleted and the temporary key renamed to take its place. It’s still technically possible to lose data if the power goes out in the milliseconds between deleting the old key and renaming the new one, but even in that almost impossible scenario, the temporary key still exists with all your data.
I tested this here and it worked. The two code paths that wrote to the permanent key used a flag to know when to write to the temporary key instead.
What I didn’t notice was that there was a third routine also writing to the permanent key, and it was only concerned with saving shelf theme data. Because I didn’t update that routine to respect the flag, it was always writing to the permanent key - which was then deleted when converting the temporary key to permanent. So that block of data was simply ignored.
I didn’t notice because I always use a global theme for everything (DarkTech), and the bug only becomes visible if a shelf uses an individual, non‑global theme. Even the tests I did in Windows 10 VMs didn’t reveal it, because applying a theme via the Themes tab applies it globally, so the bug stayed hidden.
Only when reports started coming in nearly 24 hours after the update did I realize something was wrong - and by then most users had already updated (update notifications are spread over a 24‑hour window).
I immediately knew what the problem was related to, found the missing routine, fixed it, and issued a new update notification (this only affected Nexus Ultimate and Winstep Xtreme users). Unfortunately, it’s the kind of annoying issue that even after installing the fixed version can only be corrected by re‑applying the shelf themes.
I truly hate when this happens, and it’s a lesson I should have learned long ago: do not change critical code right before a release. It also highlights that the vast majority of bugs don’t come from new code (because that’s usually tested thoroughly while you’re writing it), but from changes made to old code - you no longer have all the ramifications in your head, and since it was known good code, you assume the untouched parts will continue working flawlessly.
It is always more dangerous to modify old, existing code - and the older it is, the worse it gets - than it is to write new code.
Old code carries assumptions you no longer fully remember, hidden dependencies, and edge cases that were solved years ago and have faded from memory. Touching it often means waking up ghosts.
Another problem today is that very few users still browse forums, even ones that used to be extremely active, like Wincustomize. As a result, the number of people both willing and able to test beta builds before release has become very small. That reduces the chances of catching issues early and increases the risk that bugs only surface after a public release.
Because I’ve been making so many changes and additions lately - which is great, because it allowed me to introduce a ton of new functionality - it also means some parts of the code have become a little less stable. I fix issues as soon as they’re reported, and in the end, once everything settles, the trade‑off will have been more than worth it.
As Patrick Swayzee said in RoadHouse: "It will get worse before it gets better".
But some users simply have no patience (can't really blame them though).
I especially hate it when users uninstall the software and submit an uninstall survey with no return email address, which means I can’t contact them, and the description of the problem is so vague it’s completely useless. It’s as if they’re convinced I was already aware of the bug and simply didn’t care to fix it.
And then there are the issues caused by third‑party software - and increasingly even by Windows’ own security components.
One user thought Winstep Xtreme was crashing when, in reality, it was his GPU driver (I’d bet he was using an NVIDIA card!) that was failing while watching a video or ALT‑Tabbing from a game. The TDR reset hid the Xtreme UI for a few seconds, and he interpreted that as Xtreme crashing and restarting automatically.
He also assumed it was Xtreme because he had previously been using Nexus Ultimate, which ran perfectly for him - but shortly after upgrading to Xtreme he must have also updated his video card driver. So when the GPU driver started crashing, he connected the dots in the wrong direction: “Nexus Ultimate worked, Xtreme doesn’t, therefore Xtreme is the problem.”
And so it goes...
PostPosted: Sun Jun 28, 2026 11:54 pm
The “insidious” All Programs Grid Stack bug explained
For you to understand how sneaky these issues can be, here’s another one I just fixed - and uploaded a new build for. This time it was a silent release, since it only affected new users (first‑run or factory‑reset scenarios).
Since version 26.4, the default dock in Nexus Ultimate and Winstep Xtreme includes an All Programs Grid Stack. This feature was added back in April.
When the application runs for the first time - or when the user restores factory defaults via the Troubleshooting Options dialog - Winstep creates an All Programs Grid Stack and adds a shortcut to it in the default dock.
The problem came from the routine I use to create new docks. It’s an old routine that takes parameters indicating whether the dock should include default applications (email, browser), be empty, or include a couple of specific entries. That last mode is used to create the temporary dock shown in the theme preview in the Themes tab of Preferences. In that context, the routine does not add the default applications.
When I added the code to include the All Programs shortcut in the default dock, I forgot that this routine is reused for the theme preview dock as well.
Here’s what happened:
    Opening the Themes tab caused the application to create a temporary preview dock.
    That preview dock was then deleted, as intended.
    When a dock is deleted, the deletion routine also removes any child Grid Stacks, sub‑docks, etc., so they don’t become orphans.
    Because of the way I coded the dock creation routine, the preview dock was adding a shortcut to the exact same All Programs Grid Stack used by the real default dock (cross linked reference).
    So when the preview dock was deleted, the All Programs Grid Stack was deleted too.
    The default dock was left with a shortcut pointing to a Grid Stack that no longer existed.
    Result: every time you opened the Themes tab, the All Programs shortcut in the default dock stopped working.
Why wasn’t this found until now despite being there since v26.4?
Because nobody reported on it.
Because it only happens under very specific conditions: the preview dock only adds the All Programs shortcut if a second shelf exists and is a Grid Stack of type All Programs - which basically never happens except on first run or after a factory reset. None of the users here, including me, have the default setup.
Because I usually test themes in new releases via the Themes tab in the default shelf, so I never noticed this issue either - until now, when I happened to open the Themes tab in Preferences while testing the fix for the Shelf theme saving bug and also happened to click the dock shortcut.
I fixed it by only adding the All Programs Grid Stack shortcut when the flag to add the default applications is set.
Another story that shows why most bugs happen when modifying existing code.
PostPosted: Mon Jun 29, 2026 6:27 pm
Seems like I need to add "Preferences redesign" to the to-do list.
Some users still complain a lot about the application looking "outdated". Since the application itself is skinnable, I can only assume they mean the UI.
Who cares about functionality and content density? Gives us waaaay too much excessive padding and spacing instead, and something that will look outdated when Windows 12 comes out anyway! :D
PostPosted: Tue Jun 30, 2026 8:58 pm
Short note because I won't post often:
The popularity in so many disciplines of the "RETRO" look and feel is everywhere - Music, clothing, applications even skinning. Otherwise, nobody would make skins or applications like "StartAllBack", Start11 etc etc etc... that mimic prior Operating System look and feel.
It is impossible to please everyone and honestly, as for outdated what does that even mean? Not of this century? Maybe the flaw in that is with us, the people who like to skin. Maybe we need to up our game and create something that is totally different to everything else? I do not know.
PostPosted: Tue Jun 30, 2026 10:11 pm
I think the most important thing about this program is the desktop themes you can use to personalize Windows. I'm completely satisfied with the program's appearance, settings, and features. It's a great program! I completely agree, it's impossible to please everyone. There will always be dissatisfied users.
PostPosted: Wed Jul 01, 2026 5:17 pm
Unfortunately this is a very vocal minority, and I am not even sure if they actually are a minority.
Furthermore, unless I want to go all out with custom controls (and I don't want to go that route, been there with NeXT style controls, done that, got the t-shirt, never again thank you) I am limited by what the Win32 controls can do.
The AI suggested something like these three, but as you can see this makes Preferences HUGE (just like Windows 11 settings are HUGE these days):
There should also be a version with higher information density, but I can't get the AI to combine this with "modern UI style", it keeps giving me variations of the above two images. Anyway, I am not sure if the juice is worth the squeeze or even if something like this would be enough to satisfy those who are absolutely convinced that "new is always better" (even when it isn't).
There is also an Acrylic version, but I can't use that because Acrylic does not work with GDI controls (no alpha support), only GDI+ controls.
PostPosted: Wed Jul 01, 2026 9:50 pm
@Jorge - go with your gut feelings, intuition and instincts are wonderful things.
As for A.I - watch the news. That's me. GG.
PostPosted: Tue Jul 07, 2026 2:55 am
I recently had an interesting exchange through the uninstall survey that helped clarify something (although more feedback is needed and always welcome).
A user had uninstalled Nexus and left a short comment in the uninstall survey saying that it “wasn’t really modern” and did not fit his theme. Since comments like that are often vague and he left an email address, I asked a follow-up question: was the impression caused by the default theme, the included themes, the Preferences UI, or a combination of all of those?
The answer was revealing: his best guess was that it was the included themes.
Even more interesting, he had already reinstalled Nexus by then. After experimenting a bit, he realized he did not need to use a different theme at all - he simply used a tinted dock, matched it to his desktop, and was happy with the result. He also made a point of saying that the customization itself was great.
I think this is a useful example because it shows how quickly first impressions are formed. The software itself was not the problem. The flexibility was not the problem. In fact, once he discovered how easily the dock could be adjusted to match his system, the original objection disappeared.
But the initial visual impression still mattered.
When some users say something “looks outdated,” they may not be talking about the engine, the feature set, the level of customization, or even the Preferences UI. They may simply be reacting to the first skins or themes they see before they have had time to discover what the software can actually do.
That is valuable feedback. Nexus and Winstep Xtreme are mature, professional-grade tools with a huge amount of flexibility, but presentation still matters - especially during the first few minutes. If the bundled themes create the wrong impression, some users may never get far enough to discover the customization that would have solved the problem for them.
So this is one area I will be looking at more closely, because the first impression should better reflect what the software is capable of today. If you guys have any considerations on this I would love to read them.
Of course, the sheer number of settings and options can also be intimidating to new users. But that depth is also one of Nexus’ greatest strengths. This is not a toy with three sliders and a handful of presets; it is powerful, deeply customizable software, and there is only so much you can do to organize hundreds of options without either hiding them or dumbing the application down.
PostPosted: Tue Jul 07, 2026 3:27 am
In other news, I've been slowing getting the Theme Builder ready to be "incorporated" (or assimilated, if you are a fan of the Borg) into the main applications.
The Theme Builder's bitmap resources, etc, now exist in a single DLL that can be shared between all applications and I have changed the names of the Theme Builder source code files so they can be merged with the rest of the source code without running into name conflicts.
Slowly... very slowly... I will get there.
I've also been making some changes to the product pages on the Winstep website. Feedback is always appreciated.
PostPosted: Tue Jul 07, 2026 7:09 am
On the website www.wincustomize.com there are new themes for Winstep. Created these Picco14 themes. Thanks a lot to him! He has screenshots of other topics. It is a pity that these topics are not available.
PostPosted: Thu Jul 09, 2026 4:00 pm
Look, I do not know if this is even possible but I found a good use for a Gauge other than how much space is used/remaining in the Disk monitor if it is even possible????
It would require any skinner to be totally precise and color match and temperature match it accurately, but a Temperature Gauge visually enables them to look at a single glance how hot or stable their drive is. Just an idea. I attempted email but have given up there. As you were.
PostPosted: Mon Jul 13, 2026 4:19 am
Although the idea is not bad, the number of graph/gauge type objects you can use per module is limited. Plus, if gauge is allowed so is histogram, which means adding code to store temperature over time, etc...
PostPosted: Mon Jul 13, 2026 4:40 am
Ok, so as I was getting the Theme Builder ready to be ‘incorporated’ into the applications, I started noticing the drawbacks and kept going back and forth between doing it that way or actually keeping it as a separate application. I need to think about it more.
In the meantime, I fixed a bug that could cause multi-monitor profiles to be applied incorrectly on systems where the monitors were not horizontally aligned.
Also, the Sub-Docks dialog on the Dock’s Behavior tab currently includes an Open sub-docks on mouseover option and a configurable popup delay. It turns out that this setting already controls whether other dock popup objects - such as Grid Stacks and Launch Pads - open on mouseover as well.
A user recently suggested that folder menus should also support mouseover activation. These are the menus displayed when a folder shortcut is configured with Show Folder in a Menu in the item’s Properties dialog.
Since the existing setting effectively controls all dock popup objects - sub-docks, Grid Stacks, Launch Pads, and folder menus - it makes sense to move it, together with the popup-delay setting, to the More Options dialog on the same Behavior tab. The option could then be renamed:
Open sub-docks, Grid Stacks, Launch Pads and folder menus on mouseover
This also solves a problem in the free version of Nexus. Because Nexus Free does not support sub-docks, clicking the Sub-Docks button currently displays a promotional screen for Nexus Ultimate. In Nexus Free, the equivalent option in More Options would simply read:
Open folder menus on mouseover
That said, users of the paid versions may still reasonably expect the mouseover settings for sub-docks to be available from the Sub-Docks dialog. Rather than duplicate the controls there, I plan to add a Mouseover Settings button that opens the More Options dialog directly.
PostPosted: Wed Jul 15, 2026 9:10 am
Betas of v26.7 are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
Nexus free beta:
This is a beta and MUST be installed ON TOP of a full v26.6 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
v26.7 so far has been mainly a maintenance release (only addition is the ability to also optionally open folder menus on mouseover, like you already could with sub-docks and grid stacks). Fixes some bugs related to PWAs and Chromium browsers on per-user installations, multi monitor profiles sometimes being incorrectly applied on systems where the monitors were not horizontally aligned, incorrect rendering of the tab text in the Alarm Manager on non-Western systems, and a couple more other misc fixes and stability improvements.
PostPosted: Wed Jul 15, 2026 10:16 am
The WinStep Xtreme update to version 26.7 went smoothly.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 199 posts ] Go to page 1, 2, 3, 4, 5 ... 14  Next
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 174 guests
