Board index : Winstep Forums : General Discussion  [ 19 posts ] Go to page Previous  1, 2
 Post subject: Re: Dock full height?
PostPosted: Thu Aug 06, 2026 12:50 pm
See the difference with te previous posted desktop.
De left shelf is now stretched!
The only thing i would like to have is more icon width, so the icons are more spread over the shelf. Now they look a bit clustered together.
PostPosted: Thu Aug 06, 2026 11:19 pm
DOCK, not *shelf*! :D
I increased the maximum icon spacing from 16 to 64 pixels. I first had to make sure there would be no unintended side effects, but the code appears to handle the larger values without any issues.
Keep in mind that if the increased spacing causes the dock to extend beyond the available screen space, the application will automatically reduce the icon size in an attempt to make it fit, down to a minimum of 16 pixels.
Did you know that Winstep Nexus is one of the very few docks - and possibly the only dock for Windows - that lets users define the spacing between icons directly?
PostPosted: Fri Aug 07, 2026 3:11 am
Thank you very much!
You’re a Hero! 8)
I use Winstep already 15 years or maybe longer but never used the forum.
But I should have. Because i struggled a lot sometimes to find options in the wood of options.
Its such a flexible program with so many options.
I love it when programs are still developing and contact with the developers is a short line.
And the feeling building together users and programmers!
As a community
_/ \_
PostPosted: Sun Aug 16, 2026 3:21 pm
Thanks! I installed the Beta and it works fine!
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 19 posts ] Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], Google [Bot] and 210 guests
