Board index : Winstep Forums : General Discussion  [ 201 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 14  Next
PostPosted: Tue Aug 04, 2026 8:34 pm
Not really.
Besides, RAM usage depends on a lot of factors, what is being cached in memory, etc. Is that what you get immediately after launching WorkShelf or after some time of playing with it?
Good evening! You were right! The memory consumption spike was no longer observed.
PostPosted: Wed Aug 05, 2026 3:56 pm
I still think the culprit and the reason it only happens with Windows 11 and not Windows 10 has to do with Windows 11 support for P-Cores and E-Cores on modern Intel processors.
A slower E-core takes longer to perform the same amount of WorkShelf work.
Alas, I was finally able to eliminate this theory using Process Explorer's Set Processor Affinity feature.
With no affinity set, Windows spreads the workload across multiple cores. This made it difficult to determine which core WorkShelf was running on, even while repeatedly mousing over the dock.
After restricting WorkShelf to a single logical processor, however, all its processing remained on that core. This made it possible to confirm that the roughly 25% usage of a single CPU core while idle is real.
Switching the affinity between a P-core and an E-core made no significant difference.
I also tried profiling WorkShelf using WPR and WPA - Windows Performance Recorder and Windows Performance Analyzer - but that did not help either, because WPA was unable to load and resolve the symbols from WorkShelf's PDB file.
This is EXTREMELY frustrating... so close and yet so far!
PostPosted: Mon Aug 10, 2026 1:33 am
New Betas of v26.8 (Beta 5) are out:
Winstep Xtreme beta:
Nexus Ultimate beta:
Nexus free beta:
This is a beta and MUST be installed ON TOP of a full v26.6 OR LATER installation. Do NOT uninstall anything first, just exit all running Winstep applications and run the beta setup file.
Lots of changes, fixes and additions since the last beta.
Added new Dark Mode (Midnight) UI mode, new indicator styles for grouped task icons, increased maximum icon spacing in docks to 64 pixels, added optional Windows 11 animation (faster, snappier) for the window live preview thumbnails, added "Launch once for multiple dropped files" setting to the Item Properties dialog, fixed major bug with the multi-monitor profiles after hardening in the previous beta which would cause the monitor list not to be refreshed the second time a display change occurred with possible application crash, tasklist on a dock only updating every 10 seconds if "fast systray refresh" was enabled, plus a ton of other improvements, changes and fixes.
Full list of changes in v26.8 HERE.
PostPosted: Mon Aug 10, 2026 8:41 am
The update to beta version 26.8 (Beta 5) went smoothly. The Dark Mode (Midnight) interface theme is now available. Thank you very much!
Windows 11 Pro 26H1.
And one more question: Wanda the Fish. There are currently four animated fish species. Are you planning to add more? My child loves the animations! The fish look so realistic!
PostPosted: Mon Aug 10, 2026 3:27 pm
Unfortunately, no.
PostPosted: Mon Aug 10, 2026 4:09 pm
The lists below contain the full set of changes over v26.6 in this beta, organized by category for easier reference.
Changes applicable to Nexus Ultimate and Nexus can be extrapolated from the corresponding WorkShelf changes.
WorkShelf v26.8 Beta 5
This beta includes a substantial number of new features, improvements and fixes, with particular focus on task handling, PWAs, Windows 11 compatibility, multi-monitor behavior and resource usage.
NEW FEATURES & IMPROVEMENTS
General
  • Updated Russian language file.
  • Updated WorkShelf User Guide.
  • Improved the layout and visual presentation of the Winstep Update Manager.
  • Added new Dark Mode (Midnight) UI mode.
Docks, Shelves & Drawers
  • Renamed and moved the mouseover opening settings from the Sub-Docks dialog to the Behavior tab's More Options dialog to reflect that they also apply to Grid Stacks, Launch Pads, and folder menus.
  • Folder shortcuts configured to open as menus in their Item Properties dialog now also open on mouseover when the corresponding option is enabled.
  • Added an option to the Auto-Hide settings on the Behavior tab to keep the tab strip stationary when collapsing or expanding a floating Shelf or Drawer.
  • Added a warning when enabling full-width spanning with a tile-based dock theme, explaining that the option requires a single continuous dock background.
  • Increased the maximum horizontal and vertical dock icon spacing from 16 to 64 pixels.
Tasks & Window Management
  • Improved CPU usage when updating the list of running applications by caching previously resolved information.
  • Added new stacked-icons and no-indicator options for grouped task icons, in addition to the existing numeric instance counter.
  • Added a troubleshooting option to force tasklist polling once per second when Windows shell notifications are delayed or unreliable.
  • Added a Windows 11-style animation option for task window and menu bitmap file thumbnail previews, featuring a faster, snappier animation. The default is the Windows 11 style on Windows 11 and the Windows 7 style on earlier versions.
PWA Support
  • Added support for Vivaldi PWAs.
  • Added default PWA icon.
System Tray & Modules
  • Optimized the audio tray icon to cache the active audio endpoint and use system notifications for device changes, eliminating unnecessary device enumeration every second.
  • Added Wi-Fi signal strength display to the network tray icon when permitted by the Windows location privacy settings.
  • Added per-connection bandwidth usage information to the Net Meter's Active Connections dialog.
  • Added a text-size setting (Small, Medium or Large) to the Net Meter's Active Connections dialog.
  • Updated the Restore Wallpaper internal command icon to display the wallpaper thumbnail inside a monitor for a more polished appearance.
Alarm Manager
  • Added support for US and ISO system date formats in Alarm Manager, including locale-independent date validation.
File Drag & Drop
  • Added a "Launch once for multiple dropped files" option to the Item Properties dialog, allowing all files dropped onto an application shortcut to be passed together in a single launch instead of launching the application separately for each file.
FIXES
Themes & User Interface
  • Fixed an issue where opening the Themes tab in first-run or factory-reset setups would delete the default dock's All Programs Grid Stack target, leaving the dock's shortcut non-functional (build 1895).
  • Fixed an issue related to writing changes atomically where Shelves using individual non-global themes would revert to a generic theme after restarting (build 1894).
  • Improved readability of red warning text in the User Interface Dark mode (Gray) theme.
  • Fixed some message boxes appearing centered on the screen instead of on their parent dialog or window.
Docks, Shelves, Grid Stacks & Folder Menus
  • Fixed an issue where a Shelf, Drawer, or Grid Stack could appear unresponsive to mouseovers while a folder menu was open.
  • Fixed collapsed shelves being incorrectly resizable by dragging their edges, causing the shelf body to appear while remaining logically collapsed.
  • Toggling the "Span the full screen width when docked" option no longer resets the docking screen edge.
  • Fixed docks with automatically reduced icon sizes briefly "flashing back" to their original icon size when reset.
  • Fixed sub-docks, Grid Stacks and folder menus unnecessarily closing and reopening when auto-drop down is enabled and the mouse is moved back over their parent icon.
  • Fixed sub-docks sometimes jumping to an adjacent monitor when repositioned near a monitor edge.
Tasks, UWP Apps & PWAs
  • Fixed normal Chromium-based browser windows (Chrome, Brave) being incorrectly detected as PWAs with per-user installations.
  • Fixed grouped PWA task items displaying the browser name instead of the correct application name, such as YouTube.
  • Fixed cloaked and uncloaked UWP window notifications sometimes being associated with the wrong window, preventing the task list from updating correctly.
  • Improved handling of cloaked and uncloaked windows so UWP apps are added to or removed from the task list at the correct time.
  • Fixed unresolved UWP app windows being temporarily added to the task list with a generic icon before their application identity was available.
  • Fixed potential excessive tasklist polling when shell notifications were unavailable.
  • Fixed task icons in docks taking up to ten seconds to appear or disappear under Windows 11 when Enable fast system tray refresh was enabled.
  • Fixed a "The group or resource is not in the correct state to perform the requested operation" error when dropping multiple files onto UWP application shortcuts.
Multi-Monitor & Reserved Screen Areas
  • Fixed an issue that could cause multi-monitor profiles to be applied incorrectly on systems where the monitors were not horizontally aligned.
  • Fixed stale monitor handles after returning from a low-power state causing incorrect task filtering per monitor when switching from grouped tasks to individual task icons until the application was restarted.
  • Fixed an issue where restarting or crashing Explorer could cause reserved screen areas and appbars to be positioned incorrectly.
System Tray & Resource Usage
  • Fixed the system tray timer continuing to run even after the last tray instance had been removed, causing unnecessary background polling and resource usage.
  • Fixed occasional excessive idle CPU usage under Windows 11 by replacing continuous Core Audio device polling for the volume tray icon with device-change notifications.
  • Fixed modules inside Grid Stacks or nested sub-docks being incorrectly detected as active despite their root dock, shelf or drawer being disabled, preventing unused resources from being properly released.
Alarm Manager & Localization
  • Fixed incorrect font rendering in the Alarm Manager on systems using non-Western locales.
  • A badly formatted date in the Edit Alarm dialog no longer blocks the Cancel and Today buttons.
  • Fixed incorrect Italian spoken-time phrasing, hour/minute ordering, and time-of-day announcements.
  • Fixed the default Disk Meter desktop module translating the Read, Write, Free and Temp labels twice, which could add already translated text to language files as new entries.
Modules & Item Properties
  • Fixed an issue where changing the module type in the Item Properties dialog did not properly restore the corresponding argument field, such as the drive list for Drive modules or the time zone for Clock modules.
  • Fixed the Next Desktop Background internal command no longer working under Windows 11 by using the native Windows wallpaper slideshow API on Windows 8 and later.
Networking
  • Improved GeoIP and HTTPS socket handling, including more reliable lookup-state tracking, timeout cleanup, and reconnection logic.
Backup & Restore
  • Voice and Sound theme folders were not being properly validated when restoring from a backup.
NextSTART v26.8 Beta 5
This beta includes a range of new features, improvements and fixes, with particular focus on task handling, PWAs, Windows 11 compatibility, multi-monitor behavior and resource usage.
General
  • Updated NextSTART User Guide.
Taskbar & Window Management
  • The NextSTART Quick Launch area now animates as it expands and collapses.
WorkShelf Integration
  • WorkShelf sub-docks can now also be accessed from NextSTART hotspots, Quick Launch buttons and menus. To add one, select it from the Add > Docks submenu (sub-docks will be marked as such).
PWA Support
System Tray
FIXES
  • Fixed the icon of grouped PWA task instances not being displayed properly in the taskbar at icon sizes of 32x32 or smaller.
Multi-Monitor, Appbars & Reserved Screen Areas
  • Fixed the NextSTART taskbar sometimes not being properly repositioned when reserved screen areas changed.
Windows & User Interface
PostPosted: Tue Aug 11, 2026 7:03 am
Just added a new "Clear Temporary Files" internal command.
This came about because I'm regularly forced to manually clean the contents of the Windows and current user's Temp folders. Many applications leave behind a ton of temporary files and folders, and over time they can end up consuming a surprising amount of disk space.
My favorite culprit is Office Click-to-Run. You can't simply kill it, otherwise Microsoft Office applications stop working properly, but while it's running it constantly creates and writes to log files in the Temp folders. I tried everything I could think of to stop it from doing that, but nothing worked.
Then it occurred to me that cleaning temporary files is exactly the sort of thing that should be done automatically on a schedule, so I never have to remember to do it again.
Winstep applications already include the built-in Alarm Manager which, besides displaying reminders, can also be used to launch applications or execute internal commands. All that was missing was an internal command to actually perform the cleanup.
And so I created one.
When run manually, Clear Temporary Files reports how many files and folders were deleted and how much disk space was freed. When run from the Alarm Manager, it operates silently according to whatever schedule you choose.
I hope this is as useful to you guys as it will be to me. :D
PostPosted: Tue Aug 11, 2026 1:20 pm
Wow...just wow.
I wish other dev's without naming any, took as much pride in ensuring that everything worked as intended and not only fixed bugs, but ensure the new stuff isn't released in a state that needs production fixes perpetually. I hear nightmare stories regularly from friends that are gamers on the state of a lot of what is out there.
Amazing hard work. :D
PostPosted: Tue Aug 11, 2026 11:33 pm
Thanks Andrew, much appreciated. :D
PostPosted: Mon Aug 17, 2026 6:02 am
Jorge - Just returned from a period away and on starting my PC was notified that Winstep Extreme had an update to v26.8 beta 5. I let this happen, along with the latest Windows 11 updates. On restarting Extreme (and subsequently my PC) Workshelf was not present on screen, although it showed in Task Manager using 8.2%-8.4% CPU. Trying CTRL+F11 to bring the preferences dialogue up did nothing, although CTRL+F12 did bring Nextstart preferences up. Tried exiting and restarting Extreme a couple of times (while trying different options) to no avail. I even created a Nextstart hotspot (icon) and hotkey to bring workshelf forward, but didn't help. Workshelf is also not showing in the system icons window, although Nextstart is.
I tried reverting back to v26.6 but it didn't fix the issue.
I use Displayfusion-pro with a two monitor setup, but even disabling this and rebooting does not fix the issue.
PS - I did note that stopping / starting Workshelf does move the desktop icons up / down as if trying to make space for the collapsed workshelf - but nothing displays, and as said earlier I cannot get preferences to appear.
I can only assume that Workshelf has got itself hung up during initialisation (possibly something during update corrupted the configuration?).
I'm going to have to restore my PC back to the latest backup to see if this rectifies the issue.
PostPosted: Mon Aug 17, 2026 7:08 am
This to me seems to be the smoking gun - or at least a very important clue.
If the problem was purely caused by code changes in v26.8, reverting back to v26.6 should have immediately fixed it.
The fact that it did not suggests that either something external to WorkShelf also changed and is causing the problem or, as you also stated, v26.8 changed something in the configuration that is now causing v26.6 to enter the same loop.
8% CPU usage while WorkShelf is effectively doing nothing is massive. It strongly suggests that the application is stuck going round and round in circles in some kind of tight feedback loop, unable to do much else.
The desktop icons moving up and down when you start and terminate WorkShelf also point suspiciously at the AppBar code. AppBars are what reserve screen space for docks and shelves, and I did make changes in that area in v26.8. A feedback loop between WorkShelf changing the reserved work area and Windows notifying it that the work area has changed would certainly explain the high CPU usage.
However, if the problem were simply in the new v26.8 AppBar code, then once again reverting to v26.6 should have fixed it.
When you went back to v26.6, did you also revert NextSTART to v26.6?
Can I convince you to do a couple of tests before restoring your PC?
A PITA, I know, but it would be very important to figure out what is causing this and prevent it from happening on other systems as well.
1. Test the monitor profiles
Exit WorkShelf.
Go to the Winstep data folder - either under Public Documents or ProgramData on your system - navigate to the Profiles folder, move all the monitor profile files in there temporarily to another folder, then restart WorkShelf v26.8.
If that does not fix the problem, exit WorkShelf again and put the files back.
2. Test with a clean WorkShelf configuration
Exit WorkShelf.
Open the Windows Registry Editor and navigate to:
HKEY_CURRENT_USER\Software\WinSTEP2000\WorkSHELF
Select the WorkSHELF key and use File -> Export to save the whole key to a .reg file. This is effectively a backup of your current WorkShelf settings.
Now delete the WorkSHELF key and start WorkShelf again.
If WorkShelf now starts normally, then at least we know the problem is related to something in the current configuration.
Either way, afterwards exit WorkShelf and import the saved .reg file to restore your original configuration.
If neither of these tests fixes anything, then my suspicion would definitely shift from a change in WorkShelf to something external to it causing the issue.
ALSO: do you happen to have Process Monitor installed on your system? It would be useful to see what WorkShelf is doing during startup and, in particular, what the last recorded operations are before it gets stuck in the loop. That might help pinpoint that the problem occurs after this stage of initialization but before that one.
PostPosted: Mon Aug 17, 2026 11:19 am
Sorry Jorge, I had already reverted as I needed to get my PC working to do some tasks.
However I didn't do a recovery in the end.
I noticed that even though I had run XtremeSetup.exe for Winstep Xtreme 26.6 (as just downloaded from your website) after verifying that all Winstep processes were gone, when I checked the version indicated in Nextstart properties it still showed as v26.8!
So I moved the Nextstart, Winstep and Workshelf executables to a backup directory and then reran XtremeSetup.exe. After restarting Winstep Xtreme everything returned as expected. Workshelf showing 0%-0.5% CPU, CTRL-F11 works and shows Version: 26.6
As a further test I then replaced the v26.8 executables back into the Winstep directory (after shutting down all Winstep processes) and restarted Winstep Xtreme - the original behaviour returned. CPU usage at 8.4%, no workshelf displayed, Nextstart preferences shows Version: 26.8, but CTRL-F11 doesn't bring up Workshelf Preferences.
Note - using the menu right click -> Exit Winstep Xtreme option closes Nextstart but not the Workshelf executable (which is presumably in some locked loop). This requires the process to be ended via Task Manager
PostPosted: Mon Aug 17, 2026 11:32 am
Thanks... can you try starting WorkShelf 26.8 standalone (i.e. *without NextSTART running at the same time*), please?
Want to rule out a closed feedback loop when creating the appbars (although you exiting NextSTART and WorkShelf remaining unresponsive already partially answered my question).
Also, can you please send a backup of your WorkShelf settings to the Winstep support address? Want to check if the settings are causing the issue (could also be a combination of the settings and your system, so...)
Just to confirm, so in reality you were still running WorkShelf v26.8 too, right? Which makes sense since the installer does not replace newer files with older.
EDIT: Also, I suspect now this has nothing to do with the appbars. I think you might have a recursive chain between an object and its parent(s), and one that might even not be detected by "Check Dock Integrity" if it is nested several levels deep. I improved the code related to figuring out if the root parent of an object is enabled or not and there is no safeguard there for unlimited recursion. That backup of your settings is now more important than ever.
PostPosted: Mon Aug 17, 2026 2:55 pm
Presumably.
I have sent the Workshelf settings backup to the support email.
Just as a quick test I used the Exit Winstep Xtreme option to shutdown Nextstart / Workshelf v26.6 and ran Workshelf v26.8 directly from the executable backup directory. It exhibited the same behaviour as previously - no workshelf displayed, ~8.4% CPU, CTRL-F11 does nothing,...
PostPosted: Mon Aug 17, 2026 3:40 pm
Ok, so I was right actually, regarding the recursive items.
Version 26.8 corrected a flaw in the logic used to determine whether the parent of an object was actually enabled. Previously, the check only looked at the immediate container instead of walking all the way up to the root parent. The corrected check now follows the full parent chain, which exposed a separate problem: if the stored dock/Stack hierarchy contains a recursive or otherwise corrupted parent relationship, WorkShelf could end up following that chain indefinitely.
That explains the high CPU usage, the Shelf not appearing, Ctrl+F11 becoming unresponsive, and WorkShelf refusing to terminate normally.
I have now added safeguards so a corrupted or recursive parent chain can no longer cause an infinite loop, and expanded the Dock Integrity Checker so it can detect and repair indirect recursive dock/Stack relationships as well.
I used the new Integrity Checker on your configuration and confirmed that recursive Stacks were indeed the problem. After repairing them, the configuration works normally again.
So this one is fixed for the next build.
Thanks again for doing the 26.6/26.8 executable comparison - that helped narrow the problem down considerably.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 201 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 14  Next
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot], Majestic-12 [Bot] and 197 guests
