Board index : Winstep Forums : General Discussion  [ 36 posts ] Go to page Previous  1, 2, 3  Next
 Post subject: Re: Muti-monitors profile
PostPosted: Fri Aug 28, 2026 7:11 am
And in the end settled for this:
This was the version that I prefered ;) More natural.
Please try to use the exact Winstep terminology when describing these issues, especially when distinguishing between Shelves and Grid Stacks. Above I assume that when you say the ‘Shelf’ becomes giant you actually mean the temporary Grid Stack, since the setting you changed is ‘Grid Stack Scaling’. If that assumption is wrong, then I would be investigating a completely different problem.
Sorry for the wording. I was talking about these options but I think you figured it out in the end. So far, "grid stack scaling"should not be shared indeed due to difference in dpi in multi monitors setup.
Can you please make a backup of your settings (Preferences -> Backup) and send it over to the Winstep support address... see if I can reproduce it here.
Done: mail title = "Backup for "Muti-monitors profile" topic"
PostPosted: Fri Aug 28, 2026 10:33 am
This is an example how such a simple request can sometimes evolve into a much more complex thingy lol
Thanks, did not really help... Pretty sure it is related to the different DPIs of your monitor, and so I cannot reproduce here even with your Winstep settings.
Questions (all important):
1. What was the screen DPI of the monitor where the video was taken?
2. Was that the Primary monitor?
3. What are the DPIs and screen resolutions of all your monitors?
4. Does this happen when opening the folder as a Grid Stack from all three Shelves, or only from the Shelf on a particular monitor?
If possible, please test the same folder from each monitor and say which ones exhibit the double appearance.
PostPosted: Fri Aug 28, 2026 6:56 pm
In the end, I start to find this strange behaviour funny ahah
More seriously, here is the details of my config:
Monitor1
= Built-in Screen
= 2560x1600 on 11", around 274 dpi
Monitor2 (Primary)
= external monitor on dock
= 2560x1440 on 24", around 122dpi
Monitor3
=external monitor on the same dock as monitor2
=1920x1080 on 24", around 92 dpi
The issue occurs on monitor1 and monitor3
Same duplicated shelf on all monitors.
I tested the same folders.
When using only the monitor1 (built-in screen) and nothing else, I dont have the issue.
When using all monitors but setting monitor3 as primary display, issue is solved on monitor3 and appears on the other two.
Conclusion: the issue does not appear on "primary display". Only secondy displays have it.
PostPosted: Sat Aug 29, 2026 6:49 am
Thanks for the information, we can already see a pattern. :D However, by DPI I meant the **Windows display scaling setting**, not the physical pixel density calculated from the monitor’s size and resolution.
Please open **Windows Settings > System > Display**, select each monitor in turn, and tell me the value shown under **Scale**, for example:
* Monitor 1: 200%
* Monitor 2: 125%
* Monitor 3: 100%
These are the values I need to diagnose the problem.
PostPosted: Sat Aug 29, 2026 11:48 am
Monitor1 (built-in): 200%
Monitor2 (24 wqhd): 125%
Monitor3 (24 fhd): 100%
PostPosted: Mon Aug 31, 2026 4:24 am
Please let me know if the new beta fixes the rogue animation when opening a Grid Stack on a secondary monitor:
viewtopic.php?p=51511#p51511
PostPosted: Tue Sep 01, 2026 3:51 pm
Hey Danny.... so?
Did the new beta fix the "A bigger title appears first in the tab before showing the final UI I defined via all the options" issue?
Inquiring minds REALLY need to know :D
PostPosted: Wed Sep 02, 2026 10:18 am
Sorry I had a lot of things to do for my work.
But i've tested today and.....no still the same issue ^^ Sorry for the bad news.
PostPosted: Wed Sep 02, 2026 1:43 pm
Crap. Well, back to the drawing board.
PostPosted: Wed Sep 09, 2026 10:54 am
Managed to reproduce here and fix it, thanks. :D
PostPosted: Sat Sep 12, 2026 11:47 am
Nice ! At least it was reproducible ^^
Tell me when the fix will be implented and I will test it too to confirm.
PostPosted: Wed Sep 16, 2026 3:50 am
Beta 10 has been released, check it out and please confirm if the issue has indeed been fixed:
viewtopic.php?p=51710#p51710
PostPosted: Wed Sep 16, 2026 2:27 pm
I've just installed it and seems the issue is solved.
I will continue to test it this week as I work to see if there is someting missing somewhere, but for the moment, it is promising. Thx again.
PostPosted: Wed Sep 16, 2026 2:36 pm
Thanks for the feedback, glad it's finally fixed. :D
PostPosted: Fri Sep 18, 2026 2:59 pm
Is it me, or "grid stack scaling"has vanished ?
At least, there is something strange with the size of the grid stack.
Is it due to the beta version ?
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 36 posts ] Go to page Previous  1, 2, 3  Next
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 236 guests
