Board index : Winstep Forums : General Discussion  [ 838 posts ] Go to page Previous  1 ... 45, 46, 47, 48, 49, 50, 51 ... 56  Next
PostPosted: Mon Aug 31, 2026 6:44 pm
This is the Start menu! Where are the zodiac signs!
PostPosted: Mon Aug 31, 2026 6:53 pm
Have I been blocked? I can't add a picture.
PostPosted: Mon Aug 31, 2026 7:58 pm
No you have not. Same. every so often, the image cache size in the Webserver has to be expanded or cleared - something like that.
PostPosted: Mon Aug 31, 2026 9:59 pm
There is a size limit for image attachments, you are probably exceeding that limit. Try compressing or cropping the image.
PostPosted: Tue Sep 01, 2026 1:05 am
A message appeared: Sorry, the board attachment quota has been reached. The JPG file. Size 152 kb. Permission 560x850.
PostPosted: Tue Sep 01, 2026 1:09 am
Information
You cannot delete posts on this forum.
Why?
PostPosted: Tue Sep 01, 2026 6:50 am
Well, that message means what it means... the TOTAL amount of storage reserved for ALL attachments in this board was reached.
I blame Andrew for attaching screenshots all the time lol :D
Anyway, I've substantially raised all limits - try again, you should not have an issue now.
Yes you can, but once someone has replied, only a moderator with deletion permission can remove it. And you replied to yourself.
You can edit your own posts, no need to delete them.
PostPosted: Tue Sep 01, 2026 8:25 am
Well you did suggest I post them in fairness... I just ran with it :lol:
PostPosted: Tue Sep 01, 2026 9:46 am
I won't be posting screenshots anymore. I will only write messages. Let BassdudeNZ post screenshots. He needs it more. I love his work! He has wonderful themes! And so far he is the only one who replenishes the program's gallery! :lol:
PostPosted: Tue Sep 01, 2026 10:02 am
Ahah, I was joking, post your screenshots at will... as I said, I *substantially* raised the limits. Should have no issues for a long time to come... not even with Andrew posting screenshot after screenshot every single day ehehe (as he should!) :D
PostPosted: Tue Sep 01, 2026 5:44 pm
I would be ecstatic if others created and posted their themes. You post images when you need to by all means. It is helpful when there is a bug :)
PostPosted: Tue Sep 01, 2026 9:07 pm
@JORGE
Jorge, I know none of us are clairvoyants that I know of, but if you have an ETA on version 27, I was thinking it would be much smarter for me to wait until then before uploading the changes I have made that mainly work with the new BETA 26.9. There are a lot of re-uploads. more than 50 and less than 100.
Not everyone will download the Beta, but everyone will get the new version notification.
Either way, I think it is smarter for me to wait even if you are not sure. You have done so much work already, I can wait if you need a break which you deserve.
PostPosted: Tue Sep 01, 2026 11:12 pm
Got it working as well as I can. Designed to work with any wallpaper anyone selects regardless of colors or complexity with one exception - If the wallpaper is extremely white, the text and modules are more difficult to read. The rest of the color wheel seems to be ok.
I could make the modules even more transparent but with some colors they almost seem to get lost.
I have tested with MANY different scenes.
Shame there is no way to make the text in the modules slightly transparent or I would.
Perhaps there is, but i definitely have not learned how to do it.
However - I also tested with a Win transparency app for official windows explorer - It is pretty well balanced if anyone wishes to go the entire transparency route.
Will upload soon, this is unaffected or changed towards any updates, it had one purpose in mind - the user chooses any wallpaper from any topic they like, kind of a universal theme if that is even possible. I will possibly change the network module, I have used that model enough and may do something different.
cheers
Theme tested with 9 others example..
PostPosted: Wed Sep 02, 2026 5:51 am
I have also downloaded 28 wallpapers from wallpapers.com which I will zip and put in the wallpapers section and for credit as mentioned, this is where all attribution goes, wallpapers.com which I will state clearly. It comes to a mere 6.5mb...for those people who do not wish to download their own.
I tested in a windows background slideshow that changes the wallpaper every 1 minute and it is quite lovely with this theme. They work well.
I chose to get real ones rather than any A.I generated ones. So yes, pretty much 85%-90% of any wallpaper type, style, object, color (except bright white) should work. I can live with that. In case someone wants to know if I could make the modules with the dark grey bg more transparent, I have already tried it. The issue is with lighter wallpapers, the text becomes almost unreadable. It is almost unreadable with bright white, which I will recommend to avoid.
It comes with two wallpapers, the violet sunset above and the morning coffee.
If you want a slideshow of tested wallpapers, as I said above in the wallpapers section when I upload them in a day or so.
As you all were.
PostPosted: Wed Sep 02, 2026 7:05 am
Great news BassdudeNZ! I hope that I will be the first to download this theme! Thank you very much! :lol:
Respected Jorge! Could you please add some emoticons when creating questions and answers (for example hands - approval, gratitude, greeting)? Thank you very much! :lol:
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 838 posts ] Go to page Previous  1 ... 45, 46, 47, 48, 49, 50, 51 ... 56  Next
Users browsing this forum: Amazon [Bot], Google [Bot], ppetroff60 and 204 guests
