Board index : Winstep Forums : General Discussion  [ 1055 posts ] Go to page Previous  1 ... 67, 68, 69, 70, 71
PostPosted: Thu Sep 24, 2026 1:01 am
ppetroff60 wrote:
Respected Jorge! I have a problem. When changing the theme, the taskbar remained the same. Help me figure out the settings. Or maybe it's related to the latest Windows update?
The problem is solved! Reinstalled the program. Everything is working!
PostPosted: Thu Sep 24, 2026 1:23 am
Glad you fixed it, Peter, but next time please remember that the Winstep Wish List is NOT a topic to post issues. Just create a new topic. :D
PostPosted: Thu Sep 24, 2026 3:48 am
Yes, I realized my mistake when I posted my post on the wrong topic. I wanted to delete everything, but the forum wouldn't let me do it. Can you allow users to delete their forum posts so that such errors do not occur?
PostPosted: Thu Sep 24, 2026 4:27 am
The forum already allows users to delete their own posts provided the post has not been replied to.
PostPosted: Tue Sep 29, 2026 3:25 pm
Preferences / Menu scaling
Make it proportional please, or at the least, put a checkbox the user can click that says 'Proportional scaling'.
If a menu skinned by anyone is 250 x 500, 200% scaling should be 500 x 1000.
It isn't fully proportional, most noticeably the width. Vertical is fine.
Additionally a limit. If any skinner makes a vertical menu that at 200% it would be larger than the vertical resolution of their screen, it definitely should not squash the menu and it does. I tested all the above and purposely made some mock menus to be sure I was not imagining it. So at 200%, if it exceeds the vertical resolution it should theoretically only apply the maximum percentage before squashing and not exceed it.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 1055 posts ] Go to page Previous  1 ... 67, 68, 69, 70, 71
Users browsing this forum: No registered users and 183 guests
