Board index : Winstep Forums : General Discussion  [ 41 posts ] Go to page Previous  1, 2, 3
 Post subject: Explorer Patcher
PostPosted: Tue Sep 30, 2025 1:33 pm
It appears to me that WinStep Xtreme and Explorer Patcher are not compatible with each other. That is why I have for a test uninstalled Explorer Patcher.
The attached image 01.png (
) shows the Windows 11 taskbar icon fly out menu. With Windows 11 24H2, it has become even more useless than before. Some icons are not displayed there at all. And some functions do not work. For example, if I minimise Teams by clicking on the close (X) symbol on its menu, the program gets minimised but is not displayed at all in the fly-out menu. I had to restart Teams a couple of times, and now I am using the minimise dot that is provided by 4T minimiser. That at least works.
Any icon (minimised program) in the Windows 11 fly-out cannot be dragged into WinStep Xtreme. Unfortunately, the video I created cannot be attached here.
Unfortunately, this means that for the time being, I have to deactivate WinStep Xtreme and re-install Explorer Patcher again. I was hoping things would work better, but it looks like MS did their own things again. :(
Please have a look at this issue.
Thank you!
Thank you.
Christian
 Post subject: Re: Explorer Patcher
PostPosted: Tue Sep 30, 2025 3:10 pm
Christian M F wrote:
It appears to me that WinStep Xtreme and Explorer Patcher are not compatible with each other. !
I have moved your post from the "What's new..." into this topic since the subject in question is the same: Explorer Patcher.
If you go back a couple of posts in this topic you should notice that another user also running Explorer Patcher had his issue resolved (for him it was the Winstep application only displaying the "clone" tray icons and not the real tray icons).
Looking at the cropped attachment you provided that seems to not have been the case for you as those tray icons in the NextSTART taskbar are clearly the "clone" icons (unless the screenshot is old).
Since the Winstep tray is displaying the clone icons and not the actual tray icons, minimizing Teams to the tray is not going to show it as the "clone icons" only display the 3 system icons. No idea why the user justposted had this issue fixed but you apparently not.
Since I do not run Explorer Patcher and have no intention of installing it here, I'm going to let the other op also running Explorer Patcher (justposted) chime in. Perhaps he can be of assistance.
As for dragging tray icons out from the tray overflow/expansion window I did not even know that was possible, Anyway, that is a function that is specific to the Windows taskbar and is obviously NOT going to work with/is not supported by the Winstep system tray.
The normal (old?) way is via Windows Settings -> Personalization -> Taskbar > Other System Tray Icons. There you can select which icons appear in the tray fly out and which icons appear in the always visible portion of the tray. This method, unlike the drag & drop method, also works with the Winstep application.
But first you must figure out why the Winstep application is showing the normal tray icons when using Explorer Patcher for justposted but not for you.
 Post subject: Re: System tray icons disappeared with latest build
PostPosted: Wed Jul 01, 2026 12:16 am
Needed to bump this thread because I was in the same boat and I'm now in a situation where I have to upgrade my Win11 build to the latest but I'm double checking if this issue was solved with the latest nexus ultimate update released a couple days ago? Last time I updated to 24h2, nothing worked in the system tray. I use it as a dock with large custom icons just like the regular dock and it's essential I have it functional.
PostPosted: Wed Jul 01, 2026 12:29 am
You will never again have access to the full set of original tray icons like in Windows 10 or in the old versions of Windows 11 unless you also run something like Explorer Patcher (and even that I cannot guarantee because I do not make the latter).
Microsoft made sure of this when they deliberately removed the old structure that was for a short while still accessible beneath the new XAML tray icons.
If you are not running Explorer Patcher, you only get the three clone - but fully functional - system tray icons: battery, net and volume. You then need to click the tray expansion arrow to have access to the remainder of the tray icons (and you can control which icons appear there via Windows itself).
PostPosted: Wed Jul 01, 2026 12:32 am
I appreciate the quick reply. I do have explorerpatcher installed but that didn't seem to help either. I'll make do on the older win11 for now, thanks.
PostPosted: Wed Jul 01, 2026 1:11 am
I don't know why it worked for "justposted" also using Explorer Patcher but not for you. The Winstep application first tries to access the old tray icon structure, and only if that structure does not exist does it use the clone tray icons.
Perhaps the new versions of Explorer Patcher are no longer exposing the old structure?
It would be nice if Justposted saw this and chimed in.
PostPosted: Wed Sep 30, 2026 9:51 pm
Hello. Not been here for a while, so only just seen this. Not sure whether I can help but I can tell you that I am ...
Running the latest Nexus (26.09.1280), Explorer Patcher (26100.8457.70.3) and Windows (26H2). It was fine in 24H2 and 25H2 as well. The system tray is still working nicely for me.
For me, the right and left click functions work on the system tray as you would expect, i.e. they bring the task's window up, or allow me to close them or whatever. All good.
If there is anything I can check or try for you, feel free to ask. I'll check in here more regularly to see.
As a side point: there are currently about 300 users online. What is that about?! Usually about 10 people. Is this web scrapers and AI and China causing big traffic?
PostPosted: Wed Sep 30, 2026 10:02 pm
please update us after you update it, when you say "system tray works fine" do you mean you can make a full dock from it?
PostPosted: Wed Sep 30, 2026 10:06 pm
Still fine on 26H2. And yes, I have a full system tray dock. Image attached.
PostPosted: Wed Sep 30, 2026 10:14 pm
I'll give updating a shot, thanks for the input!
PostPosted: Wed Sep 30, 2026 11:03 pm
Thanks for coming back. You're proof that Explorer Patcher can be made to work with Windows 11 in order to show the system tray on the dock.
Web scrappers, AI and spam bots, you name it. I wish it were real users ehehe
At one point there were over 13,000 (!) of them online. Situation got so bad that I had to do some changes to the forum code itself to filter out unwanted guests without affecting legit users with actual forum accounts.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 41 posts ] Go to page Previous  1, 2, 3
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 190 guests
