 Post subject: Request for Next Version or Update if possible?
PostPosted: Fri Apr 11, 2008 8:15 am
I would like to see a Zoom on One line. In other words you could make it (line) thin and reach all the way accross the screen. The Cursor would be active inside the line where you could move it, and also click on whatever you wanted to.
that would be great for people that can't see good. I have glasses and even with the glasses sometimes I have trouble reading text (even on this forum)
another suggestion would be to make it an option where you can change the size of the Fonts (without changing anything else) on the Tabs on the workshelf.
there is a program on snapfiles.com that will magifiy the text under the cursor however it doesn't work correctly. I get an error everytime I try to run it. The author is no longer supporting it. It is Freeware.
that one has a Square that surrounds the cursor wherever it moves to.
I think that would be a great addition to the New (version and/or update) to the next workshelf.
One other suggestion is a Memory Set. what I mean to say is if you are running a heavy graphics program make the memory where it will put most of the memory on what ever program you are running instead of making it let the machine decide which program the memory (ram) goes to.
Just some suggestions I had in mind.
thanks
3flash :wink:
My Sales Page
Users browsing this forum: Amazon [Bot] and 214 guests
