 Post subject: Screen Shot Tool
PostPosted: Sun Apr 20, 2008 6:30 am
Sorry to be such a noob but I figure the only stupid question is the one that never gets asked. My dad recently passed and I inherited his laptop. It has what is apparently an older version of Winstep on it. God I Love This Tool. I am trying to find out what screen capture program is used in the newer versions so I could integrate it into mine. Any and all help is greatly appreciated. Thanx from a grateful Marine.
Semper Fi
PostPosted: Tue Apr 22, 2008 7:27 am
Hi Gunny.
I'm very sorry for your loss... :( I hope you don't mind me asking, but what was your dad's name?
As for the screenshot tool in Winstep Xtreme, it's a built-in internal command that is part of WorkShelf and NextSTART, not a separate utility.
Take care,
PostPosted: Wed Apr 23, 2008 2:50 am
Thank you Jorge. His name was Herbert. Is there an update or something I can purchase to obtain this feature. Also, are there any kind of tutorials on ways to design themes of my own?
Semper Fi
PostPosted: Wed Apr 23, 2008 11:56 am
Hi there. I'm also sorry to hear of your loss. I don't mean to highjack your thread, but as you said...
So... What does the internal Capture Desktop command do? I've never used it and thought I'd check it out. I've created a hotspot button for it and don't see what it does. I expected it to be the same as the 'Print Screen' button on a keyboard. But there's nothing in my clipboard. What am I missing?
http://www.scarebear.org/
PostPosted: Wed Apr 23, 2008 1:56 pm
It doesn't capture to the clipboard - it goes one step further and saves the a screenshot of your desktop into the well, Windows Desktop, as a JPG file.
PostPosted: Wed Apr 23, 2008 2:01 pm
Send me an email to support@winstep.net and I'll send you a link from where you can upgrade from the old Winstep Full Pak to Winstep Xtreme.
There is a skinning tutorial on the Help section of the Winstep web site. It is very old, though, but should be enough to get you started. :D
Best way is to choose an existing theme, together with a printed list of the bitmap names used which you can find in the NextSTART and WorkShelf User Guides, and experiment to see how the bits and pieces fit together.
PostPosted: Wed Apr 23, 2008 9:36 pm
Cool. Thanks!
Users browsing this forum: Google [Bot] and 179 guests
