 Post subject: Problem with task manager in nextstart
PostPosted: Fri Oct 31, 2008 11:53 pm
I have the next problem :cry: , every time I left click on a task in the taskbar of nextstart the window lost the maximized attribute and restores to another size and re ubicate atached to the right low corner of my screen, all maximized windows takes this behavior, I'm using stardock windowblinds, stardock keyboardlaunchpad and winstep xtreme trial, how can I resolve this?, tahnk you in advance
PostPosted: Sat Nov 01, 2008 6:05 pm
Ooops. Looks like a bug, sorry. :(
Wonder how something like that wasn't mentioned by any of the 8.9 beta testers?!! Isn't anybody running maximized windows anymore (I know I'm not :( )? :shock:
I'll have it fixed ASAP.
PostPosted: Wed Nov 05, 2008 7:17 am
Hmm, I run apps maximized most of the time and never noticed a
problem before.
I maximized a few apps just now and clicked on the different task icons,
everything stays maximized (well, they go from min to max).
Running Xtreme 8.9 on XP Pro SP3.
Marc
== ANIME SENSHI ==
Marc D. Williams
PostPosted: Wed Nov 05, 2008 3:59 pm
But you're not running Vista, and he is (and so am I).
Under Vista, high privilege windows ignore messages sent to them by windows with lower security privileges.
In Vista a different method, which works with all windows regardless of privilege level, has to be used to restore minimized windows.
It is this different method that is flawed.
PostPosted: Wed Nov 05, 2008 5:33 pm
Ok, fixed this bug for the next release.
PostPosted: Tue Nov 18, 2008 10:41 am
You might want to go download the brand new public beta of Xtreme 8.11... :wink:
PostPosted: Fri Dec 19, 2008 2:19 pm
i still run into this problem occassionally, running vista ultimate x86, and newest final of 8.11
Users browsing this forum: Amazon [Bot] and 179 guests
