 Post subject: Cannot reserve Screen Space on primary monitor
PostPosted: Mon Nov 10, 2008 8:27 pm
I recently purchased Winstep Xtreme 8.9 instead of trying it first, big mistake, I normally try before I buying software.
I got through the hassle of registering it, that was an experience!
After the install it has Workshelf positioned half way down my 24" monitor and I cannot Maximize any windows.
I tried turning off Workshelf and leaving just Nextstart running no dice!
With both Workshelf & Nextstart turned off my windows can again be maximized.
I went into the Global Preferences panel of NextStart and made sure that the Reserve Screen Space setting was set at zero.
Has anyone experienced this problem?
I have sent Jorge a couple of emails, but in the mean time I thought I would post here to see if anyone had this issue.
Any help would be appreciated, thanks in advance.
:?: [/b]
PostPosted: Mon Nov 10, 2008 8:56 pm
Hi!
I replied to your emails yesterday! Can you please check your spam filter? They probably got trapped there.
 Post subject: Reserve Screen Space - Solved
PostPosted: Tue Nov 11, 2008 4:35 pm
Screen problem solved, thanks to Jorge, the man is a genius!
He suggested I checked my DPI setting and that was the problem!
Thanks again Jorge!
PostPosted: Tue Nov 11, 2008 4:49 pm
Glad I managed to solve your problem. :D
Users browsing this forum: Google [Bot], winstep and 202 guests
