Board index : Winstep Forums : General Discussion  [ 21 posts ] Go to page Previous  1, 2
PostPosted: Sun Nov 30, 2008 11:39 am
Did you delete the CTRL+F9 hotspot?
Also, when you exit NextSTART, what are your Windows taskbar settings? Always on top? Auto-Hide? How may task rows? Is it horizontal?
PostPosted: Sun Nov 30, 2008 3:24 pm
I did not delete the Hotspot (#4)...however, that does not mean I did not mess something up :D At one point I did accidentally change the #0 Hotspot, but I realized my goof and fixed it.
The Win Taskbar is: always on top, does NOT autohide.
One task row (see comment below).
It is horizontal at bottom.
One maybe related oddity. If I apply the theme Atmospherica (one of the first I used and liked), it forces my taskbar to show two rows...and I cannot make it go back down to one by simply resizing with mouse. If I remove "systray" from displayed items, it will go back down to one row.
Other themes (like Aero, and K-Tek 4D) it uses one row always (which is what I want).
Hopefully that helps. And THANKS!
I am wondering if I did really mess some setting up, if I should completely remove WS and re-install it from scratch.
kwickone I.T.H.
PostPosted: Sun Nov 30, 2008 3:28 pm
One more thing I noticed on 8.11 b1. A single quick click on apps in the taskbar does NOT always "activate" (maximize or restore) them.
If I wait until the cool Win7 preview box comes up, then it works every time. But sometimes I just quickly click and want the app to show...and it does not. Sometimes a double click works.
Hope that makes sense.
kwickone I.T.H.
PostPosted: Sun Nov 30, 2008 8:51 pm
Thanks!
Any chances of a screenshot of your desktop showing the taskbar and the systray? You can send it to the Winstep support address if you don't want to post it here.
PostPosted: Mon Dec 01, 2008 3:51 am
Thanks!
Sent the support address an email with pics. Thanks.
kwickone I.T.H.
PostPosted: Tue Dec 02, 2008 4:48 am
Jorge, FWIW, I think there was something messed up with my install (also seeing NextStart hogging cpu and not responding). I removed WS, then re-installed. All appears to be working again, including Ctrl+F9.
Thanks.
EDIT: I stand corrected. Ctrl+F9 has stopped working already. I did not change anything...other than the desktop background, and maybe a Nexus setting for activate on edge screen bump.
kwickone I.T.H.
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 21 posts ] Go to page Previous  1, 2
Users browsing this forum: No registered users and 200 guests
