 Post subject: disable the changing of wallpaper when i apply a theme?
PostPosted: Tue Dec 16, 2008 12:34 pm
how can i make it so that when i change a theme, the wallpaper doesn't change. all the wallpapers are either poor quality, or the wrong size for my needs, or simply not something i want. but i find that if i apply a wallpaper, then apply a theme, it changes and i don't want it to
PostPosted: Tue Dec 16, 2008 11:30 pm
Personally i right click on the startbar and choose "Nextstart Preferences". Then i click on the "Theme Management" tab. Then, i click on "Theme Options" and then check "Lock Wallpaper". Then click ok, apply and ok to exit all the open preferences windows.
PostPosted: Wed Dec 17, 2008 1:03 pm
i tried that, i found that in the help documentation, but it doesn't work for me, it still applies the theme specific wallpaper
PostPosted: Wed Dec 17, 2008 6:33 pm
Please specify, in step-by-step detail, what you are doing to 'lock the wallpaper' and then to apply a theme which still changes your wallpaper.
Users browsing this forum: No registered users and 183 guests
