 Post subject: Missing Icons - Help, Please!
PostPosted: Wed Dec 31, 2008 3:49 pm
Somehow icons in Winstep Menu Organizer have been deleted. How can I get them back? All my Graphics and CD-Burner icons are gone and I really need to restore them if I can. I am using Windows Vista 64-bit, and REALLY want to avoid a System Restore.
If I can't get them back, is there some way I can add programs to Start Menu>All Programs? I've tried looking all over Google and even Technical Support, but no-one seems to have the same problem.
Thank you in advance,
Kallie
PostPosted: Fri Jan 02, 2009 7:27 pm
Hi Kallie!
How did the icons disappear?
Anyway, when you run the Winstep Start Menu Organizer for the first time, it automatically creates a backup of your pre-Organizer Start Menu folder organization and shortcuts.
Click on 'Main' and 'Restore Start Menu'. You should be presented with a list of at least one entry: the one we want says 'Initial Start Menu Backup'. Select it and press Ok to restore your Start Menu to what it was before you used the Organizer to make changes.
Please let me know how it went.
Thanks,
Users browsing this forum: Amazon [Bot] and 186 guests
