 Post subject: NeXuS
PostPosted: Mon Jan 19, 2009 6:03 pm
Is there any way to make NeXuS load independently of workshelf, or to leave it working when workshelf is closed making it work somewhat like Stardock's ObjectDock?
Dr.J.
PostPosted: Mon Jan 19, 2009 9:08 pm
NeXuS and WorkShelf share the same executable.
This said, provided you are running the latest Winstep Xtreme version, you can simply right click the 'NeXuS control icon -> Dock and Shelf Management -> Close Shelf' to prevent the Shelf from appearing on your screen.
If you later want it back, do the same but chose 'Open Shelf' instead. :D
 Post subject: thanx
PostPosted: Tue Jan 20, 2009 1:33 am
thanx for the prompt answer, Jorge.
Dr.J.
Users browsing this forum: Amazon [Bot], Google [Bot] and 169 guests
