 Post subject: Windows 7
PostPosted: Wed Jan 21, 2009 11:10 am
Will Winstep work ok with Windows 7?
Great program, love Winstep.
Thanks...Steve
PostPosted: Fri Jan 23, 2009 11:53 pm
Ok, just tested Winstep Xtreme on the public beta (build 7000) of Windows 7. It works, except for some problems with the systray.
PostPosted: Sat Jan 24, 2009 9:11 pm
Will the Nexus part of it work ok with Win7?
PostPosted: Sat Jan 24, 2009 11:00 pm
Based on what Jorge said one post up....yes.
kwickone I.T.H.
PostPosted: Sat Jan 31, 2009 1:22 pm
@ Winstep
Do you intend to implement the superbar feature of Win 7 and IE 8 that
shows thumbs of all tabs ? ( in Vista with IE 8 ).
Up to now only the active tab is thumbnailed!
Or is this only a Win 7 interface ?
PostPosted: Sat Jan 31, 2009 1:34 pm
It will all depend on wether the windows thumbnail API has been extended to support this or not. But, if it does, it will probably be a feature available under Win7 only. Or I might be able to come up with a work around that also works in Vista... we'll see, it's too early to say. :D
PostPosted: Thu Mar 05, 2009 10:55 pm
Hey Jorge, I am going to give Windows 7 a run here shortly. Based on what you know and your tests, it the "Problems with the systray" you mentioned similar/same to that of Vista?
Do you think they will be fixed with the Vista systray issues in the next release?
Thanks.
kwickone I.T.H.
PostPosted: Sat Mar 07, 2009 6:23 pm
OK, just saw what you meant by the "systray issues". Not the same issue as vista....I hope you can take a look at that (even thought Windows 7 is just a beta)....I am liking Windows 7 and may keep it for a while as my primary OS.
We shall see....
kwickone I.T.H.
PostPosted: Sat Mar 07, 2009 7:14 pm
:D
PostPosted: Sun Mar 08, 2009 5:43 am
:D
It is pretty sad...and probably very frustrating...but being a techy geek, I have no choice but to run the latest and greatest...I assume you understand where I am coming from and can help a brotha' out!
kwickone I.T.H.
PostPosted: Mon Mar 09, 2009 2:48 pm
As an update to my Windows 7 experience. I am now just using Workshelf, due to the NextStart systray issues.
I am running the 64-bit version of Win 7 (build 7000). The CPU meter is not working properly. It will show a CPU load of zero at all times. In the top procs list, I see the percentages ok, but most process names (but not all) are blank).
EDIT: I am noticing that a lot more of the icons are showing up as puny...I had mentioned this before in a post before my time on Win7....but it only happened on a couple icons.
Based on these items, I am going to stop using Workshelf as well...unitl I decide to go back to Vista...or until there is a fix on the WinStep side. I understand that I am not using a supported OS, so I certainly do not expect to have a fix any time soon.
Thanks.
kwickone I.T.H.
PostPosted: Mon Mar 09, 2009 3:32 pm
Thanks for the feedback... :D
Using the 64 bit version of a Windows version yet to be released isn't helping much, though... :wink:
PostPosted: Sat Mar 14, 2009 1:36 pm
FYI, in case anyone is following this topic :roll:
My time with Win 7 was VERY short. I found it too slow (yes, believe it or not). Maybe that was due to the debugging/feedback code MS put in there. And there were several "glitches" with programs that I like to use, including Winstep.
So I am back on W2K8 (which is pretty much same core as Vista, but faster). Winstep works just like on Vista :D
kwickone I.T.H.
PostPosted: Sat Mar 14, 2009 3:17 pm
I perfectly understand the need to try the latest and greatest, but deciding to permanently dive into a beta version of an OS (or being the 'early bird') is asking for a lot of trouble and frustration while you wait for Microsoft and third parties to fix any glitches.
You better off like this, trust me. :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 212 guests
