 Post subject: Auto Drop Down setting resets
PostPosted: Mon Jun 15, 2009 8:57 am
Jorge:
This is a weird one...
On my NextStart Menu Preferences, the "Auto Drop Down" setting periodically resets so that my menus do not automatically open. I have saved the settings and backed them up, yet at random times I have to re-check the Auto Drop Down check box.
I should have tried reloading the backup to see what happens...but forgot. I'll do that the next time.
Does this make any sense to you?
Lee
PostPosted: Mon Jun 15, 2009 9:43 am
Hi Lee!
What's your NextSTART build number? If it's 9.5.0.503, you need to download and install the silent update I issued a couple of hours after the official release when I figured out the Auto Drop down settings were broken:
http://www.winstep.net/xtreme-exe.zip
PostPosted: Mon Jun 15, 2009 9:54 am
You sneaky devil....guess I must have downloaded it too fast. I do,in fact, have build 503.
I'll try the new one and see what happens.
PostPosted: Mon Jun 15, 2009 11:26 am
I can tell you what happens: your auto drop down settings start "sticking" as they should have in the first place. :wink:
Users browsing this forum: Google [Bot] and 175 guests
