 Post subject: Magnification Settings not working
PostPosted: Mon Aug 03, 2009 4:41 pm
I'm using 9.7 beta2 with the Leopard Theme (but all themes have the same result).
When i go to Effects > Select Magnify, then Effect Settings, any value that I enter for Magnification Size does not change the dock. The magnification size is always the same.
Any ideas?
thanks in davance.
PostPosted: Mon Aug 03, 2009 7:57 pm
Ah, right you are. I just fixed it and issued a silent update which you can download from
http://www.winstep.net/nexus.zip
Remember to exit Nexus before running the installer and then install the update on top of your current installation.
Thanks for letting me know about the problem.
PostPosted: Mon Aug 03, 2009 8:26 pm
Jorge, I have just downloaded and installed this version, as soon as I click preferences a dilaog pops up telling me that this beta version has expired and Nexus exits.
Best regards
PostPosted: Mon Aug 03, 2009 8:32 pm
$"#$"#$ Hold on!
PostPosted: Mon Aug 03, 2009 8:35 pm
Ok, please download again and let me know... :cry:
PostPosted: Mon Aug 03, 2009 8:53 pm
Yep everything working fine now.
:D
PostPosted: Mon Aug 03, 2009 9:08 pm
Thanks!
Seems that, in my hurry to get the Magnify Settings problem fixed, I forgot to set the anti-tampering file header properly - good thing this was fixed in less than half-an-hour, it's bad enough that so many users did not get the beta 2 update warning from the Winstep Auto Update Manager before beta 1 expired. :cry:
What still amazes me is that, although the announcement for the beta 2 release was on the Winstep web site on July 30th, lots of user apparently didn't even bother checking the site.
PostPosted: Tue Aug 04, 2009 1:45 am
that worked. thanks so much! :)
Users browsing this forum: Amazon [Bot], GPT [Bot], ppetroff60 and 132 guests
