 Post subject: Configure Folder As Menus ONLY-with new Theme?
PostPosted: Wed Aug 05, 2009 5:52 pm
I'm a new user. I have:
NeXuS.exe File Version: 9.07.0831
NexLcontroIs.oc File Version: 1.00.0151
Region.dll File Version: 1.00.0001
wsZip.dII File Versiont 1.01.0000
wsUnzipdll File Version: 1.0.0000
I would like to know if it's possible, and how to install or configure a new Theme so I can use only the Folders As Menus part of it.
In other words, I like pretty much like everything I have for my present configuration, except for the Folder Menu.
I saw the example of one I liked (Folder Menu) but haven't downloaded it yet and want to use that, but don't want the rest of the new Theme shown.
PostPosted: Wed Aug 05, 2009 7:01 pm
I'm sorry, Windy, but I'm not sure I understand what you want?
You want to use another skin/theme for the Nexus context menus, is that it?
PostPosted: Wed Aug 05, 2009 9:27 pm
I'm not so sure about the Context Menus, but I was more concerned about the Folder Menus.
I'm talking about the menu that pops up if you left-click and hold on a folder.
I would like to use a third-party Themes Folder Menu without using the rest of their theme and integrate it into my current Theme.
P.S. The feature that is supposed to work without holding it doesn't work. Someone else had the same problem. I'll post about it in that thread.
PostPosted: Thu Aug 06, 2009 12:40 am
Sorry if I'm confusing you. Is the Context Menu one in the same as the Folder Menu?
I assume that they are separate. If they function together that's fine with me just as long as I can change the Folder Menu to the Theme I want.
Users browsing this forum: Amazon [Bot], Google [Bot] and 205 guests
