 Post subject: Taskbar Doesn't change
PostPosted: Mon Oct 05, 2009 5:42 am
Hi all--
A noob to winstep and I guess I'm overlooking a setting somewhere. When I change themes, the taskbar doesn't change and stays the same. Otherwise, a neat little program.
Thanks.
-s
PostPosted: Tue Oct 06, 2009 10:37 am
Do the menus change? Otherwise you might have disabled 'Theme Integration', in which changing a theme in WorkShelf also changes a theme in NextSTART and vice-versa.
Go to the Themes Manager tab in Preferences (either NextSTART or Workshelf, doesn't matter), click on the Theme Options button and make sure 'Enable Theme Integration' is set.
PostPosted: Thu Oct 08, 2009 1:34 pm
Thanks Jorge--
I figured out what I did. Thanks for the reply.
I DO have another question. :D
Users browsing this forum: Google [Bot], ircus, winstep and 187 guests
