 Post subject: Active Tasks
PostPosted: Mon Oct 12, 2009 10:42 am
Hi All--
Can I change the attributes of the "Active" or "Running" tasks running in the startbar? I would think so, but I can't find where.
I'd just like to change the font color(s).
Thanks.
PostPosted: Mon Oct 12, 2009 3:23 pm
You can change the colors of the active tasks (open apps) in the start bar by right-clicking on the bar, selecting NextSTART Preferences, going into the Appearance Preferences menu (click on the icon with the brush and a window), and then clicking on the Tasklist button under Task Management. If you change the Background/Normal text color (click on the color to select a new one) to something else, and then click OK, the labels on the taskbar will reflect the change.
Change foreground color for the selected app's color, and mouseover color for when you drag the pointer over 'em...you know the drill.
I hope this helps, and that I understood correctly what you wanted.
I'm not a representative of WinStep or the website; any opinions or advice provided in my posts are mine alone.
PostPosted: Mon Oct 12, 2009 5:41 pm
Yup. That was what I was looking for. I guess Taskbar, Startbar, Tasklist, Active Tasks....are just too many synonyms for me to keep track of.
Thanks very much.
Users browsing this forum: Amazon [Bot], Google [Bot] and 200 guests
