 Post subject: Tabbed NeXuS
PostPosted: Wed Oct 28, 2009 12:33 pm
Looking at the Winstep homepage, if you expand the Dragon Xtreme image at top right you see sitting above the Shelf a NeXuS dock that has tabs, as opposed to the NeXuS dock at the top of screen that has no tabs. How do you create tabs on a new NeXuS dock like that? Nothing I try in settings seems to work.
PostPosted: Wed Oct 28, 2009 2:38 pm
The tabbed dock is called a 'Shelf', and is only available in Winstep Xtreme, which is shareware.
PostPosted: Wed Oct 28, 2009 3:08 pm
Yes I have bought a registered version of Winstep Xtreme, wasnt aware you could have multiple shelfs up though.
PostPosted: Wed Oct 28, 2009 3:11 pm
You can't have multiple Shelves, what you can have is a single Shelf with multiple tabs. Eventually Winstep Xtreme will add support for multiple Shelves (or tabbed docks, as you called them) but for now there can only be one.
PostPosted: Wed Oct 28, 2009 3:13 pm
Of course, now that you mention you have purchased a license for Winstep Xtreme, are you actually running Winstep Xtreme instead of the stand alone version of Nexus?
PostPosted: Wed Oct 28, 2009 3:32 pm
Yes, running full version with NexStart and WorkShelf. 9.5
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 188 guests
