 Post subject: deleting hotspot button
PostPosted: Sun Nov 08, 2009 12:07 pm
hi just got the trial and so far very impressedso far, but of course got a few questions too,
ive got a hot spot button that i cant delete, the tab at the top says its the hot spot button properties, how do i remove this?
when i right click then click on delet it says
"hotspot 0 cannont be deleted here!"
thanks
PostPosted: Mon Nov 09, 2009 3:31 pm
Hotspot 0 is the hotspot that gives you access to the main NextSTART menu, which is why NextSTART is not letting you delete it. The button itself will only show up if you have disabled the NextSTART taskbar, however.
This said, you can prevent the button from appearing on your desktop by opening NextSTART Preferences, navigating to the Hotspots Editor tab and then changing the activation method (Launch With) of hotspot 0 from 'Left Click on Hotspot Button' to, say, 'Bump Top Left Screen Corner'.
Users browsing this forum: Amazon [Bot] and 170 guests
