 Post subject: Sounds return
PostPosted: Wed Dec 09, 2009 3:16 am
Ver 9.12 Beta 6 is really great.
I run XP SP2 with system sounds firmly off.
When I change a dock or shelf setting, system sounds are turned back on
even though the 'Disable all sounds and voices' box is ticked in Workshelf.
PostPosted: Wed Dec 09, 2009 8:50 pm
By 'system sounds' do you mean Windows sounds or WorkShelf specific sounds (Shelf collapsing/un-collapsing, opening Preferences, etc...)?
PostPosted: Wed Dec 09, 2009 9:57 pm
The annoying Windows sounds
PostPosted: Wed Dec 09, 2009 10:18 pm
The 'Disable all Sounds and Voices' setting in WorkShelf has nothing to do with Windows, just with the sounds produced by WorkShelf itself.
PostPosted: Thu Dec 10, 2009 8:15 am
OK but the problem dose exist
Users browsing this forum: Amazon [Bot] and 141 guests
