 Post subject: Winstep skin from main page
PostPosted: Wed Jan 13, 2010 2:35 pm
Where can I get the flat shelf for Nexus that is on the main page?
I have looked around and can not find it.
Thanks...Stephen
PostPosted: Wed Jan 13, 2010 11:43 pm
How about a link to the screenshot/image itself?
PostPosted: Thu Jan 14, 2010 12:21 am
http://www.winstep.net/
It is the dock on the main page.
It is the flat shelf. I can't find it.
Thanks...Stephen
PostPosted: Thu Jan 14, 2010 1:45 am
You mean this one?
PostPosted: Thu Jan 14, 2010 10:38 am
That is it. Where can I get it. I looked in the themes on Nexus but could not find it.
Thanks...Stephen
PostPosted: Tue Jan 19, 2010 12:48 am
Through the WorkShelf Preferences click on the Themes tab >click pulldown arrow and scroll to NeXus >Leopard.
To get to the WorkShelf Preferences click on the little arrow at the very top left of the WorkShelf.
Or, right-click on Nexus >Appearance and Sounds >NeXus Themes >Leopard.
Let me know if things worked out. If something I said is incorrect, the master (Jorge) can straighten it out. :D
PostPosted: Tue Jan 19, 2010 11:01 am
Thank you very much. I didn't have Leopard installed.
I got it to work.
Thanks...Stephen
PostPosted: Wed Jan 20, 2010 8:04 pm
Hi, I am new to this and would like to also be able to use the Leopard skin.
Where and how do you get it ?
Thanks in advance.
freeman
Robert L Crane
PostPosted: Wed Jan 20, 2010 8:33 pm
Are you running Nexus or Winstep Xtreme? What version?
PostPosted: Sun Jan 24, 2010 1:15 am
Meu amigo, desculpe escrever em português de novo. Acho que vou ser expulso do forum.
Eu estou com versão mais recente mais também não tenho Leopard skin. Por que isso?
Tradução:
My friend, excuses to write in Portuguese again. I think what I am going to be expelled of the forum.
I am with more recent version more also I have not Leopard skin. For what that?
Obrigado ...
Fabricio
Users browsing this forum: No registered users and 192 guests
