 Post subject: nexus dock support docklets?
PostPosted: Thu Nov 13, 2008 3:35 pm
i have object dock pro, but i like how wheni change the theme in winstep, it changes the dock auto, so i'm wondering if the nexus dock will let me use docklets and spacers alot like i do in object dock pro
PostPosted: Thu Nov 13, 2008 6:01 pm
You can use spacers (called 'dock place holders' in NeXuS), but ObjectDock docklets are NOT supported, sorry.
Once the new UI is complete, you will see an 'explosion' in terms of available NeXuS docklets/modules - ideas is not something I have a lack off! :wink:
PostPosted: Thu Nov 13, 2008 6:06 pm
so there are no docklets at all now?
PostPosted: Thu Nov 13, 2008 7:59 pm
Yes there are, but they are called 'modules'.
Currently you have:
1 - A speaking clock that synchronizes the time with Internet time servers.
2 - A Recycle Bin that tells you how many files are in it and the space used by them.
3 - A speaking, multi-account, Email Checker module that is able to handle POP3 as well as IMAP mail servers and supports the SSL protocol (the later essential if you want to monitor your Gmail account).
4 - A Weather Monitor with 5 day forecast supporting over 15,000 cities all over the world which can retrieve information from METAR and Weather.com sources.
5 - A multi-processor compatible CPU Meter which is able to list current x CPU hogs.
6 - A RAM Meter which is able to list the current top x memory hogs.
7 - A Net Meter monitor which provides a mind boggling array of information concerning your network connections/cards and allows you to see which applications are currently communicating via TCP/IP or UDP, resolves IP addresses into domain names, performs WhoIs Queries and allows you to forcefully close a connection if required (in fact it matches Sysinternal's TCPView in terms of what in can do).
8 - And finaly but not the least, Wanda, a cute fortune cookie reader (VERY popular under Linux :wink: ) which is able to retrieve and display fortune cookies from an online database containing thousands of entries.
You also have two 'flavors' of each module: in-shelf/in-dock (i.e. like the ObjectDock docklets) and Desktop modules. Desktop modules can be left floating on your desktop, hidden until required, or even attach themselves to the NextSTART startbar.
PostPosted: Fri Nov 14, 2008 12:07 pm
Currently you have:
ok, so they are all built in, there is no way to create user created modules?
PostPosted: Fri Nov 14, 2008 6:07 pm
No.
 Post subject: Re: nexus dock support docklets?
PostPosted: Mon Aug 16, 2010 1:22 pm
So that was two years ago. Where is that explosion of 'modules' you were talking about ? How do I add a module that would check my emails for instance ?
Great job ! Thanks to all the devs :)
PostPosted: Mon Aug 16, 2010 1:32 pm
Read again what I said at the time:
"Once the new UI is complete, you will see an 'explosion' in terms of available NeXuS docklets/modules"
Winstep Xtreme v10.6 was released in July 13th, barely one month ago, and it's the first official release with a complete new UI. You seriously expect me to add an 'explosion' of new modules in under a month? :lol:
Err, right click -> Insert New Item -> Module -> Email Checker. Pft. :wink:
PostPosted: Mon Aug 16, 2010 5:53 pm
hahaha !
Alllll right ! My mistake on the dates ;) I shall be patient then :) It's band new for me wanted to play with all options and add more bouncing things :) Found the eMail
Couldn't get my GMail to connect yet, but as you saw, I'm not exactly computer skilled :D
Thank you !!
PostPosted: Mon Aug 16, 2010 6:24 pm
Unfortunately Gmail did something in early 2010 that now prevents the Email Checker from working with Gmail accounts (even though the Winstep Email Checker supports SSL encryption). :(
PostPosted: Fri Dec 27, 2013 8:59 am
still waiting? nearly 2014...
PostPosted: Fri Dec 27, 2013 3:58 pm
Waiting for what?
Users browsing this forum: Google [Bot], GPT [Bot] and 105 guests
