 Post subject: Winstep Start Menu Organizer Pro working ?
PostPosted: Wed Oct 27, 2010 8:58 am
hello just trying out Winstep Start Menu Organizer cant seen to get it to work correctly
i run the program make changes to the start menu but ...... the start menu is not updated to show changes
running win 7 64 bit if that helps
 Post subject: Re: Winstep Start Menu Organizer Pro working ?
PostPosted: Wed Oct 27, 2010 12:14 pm
Did you hit the Apply button first?
PostPosted: Wed Oct 27, 2010 1:08 pm
yes still no change
PostPosted: Wed Oct 27, 2010 1:33 pm
Eh?
That's not possible, sorry. :P
We are talking about the *Windows* Start Menu, not the main NextSTART menu, right? Can you please post a screenshot of the Start Menu Organizer with the changes you made and the Windows Start Menu without those changes (pressing the PRT-SCR key will capture a screenshot of your desktop and put it in the clipboard, from where you can then paste it into a graphics program, if that helps)?
PostPosted: Wed Oct 27, 2010 1:45 pm
here you go
PostPosted: Wed Oct 27, 2010 1:46 pm
Where? :wink:
PostPosted: Wed Oct 27, 2010 1:58 pm
you should see the pic now
PostPosted: Wed Oct 27, 2010 2:10 pm
Yes, now I do.
I think I understand what the problem is... You expect the Start Menu to look like the Categories panel on the left. Well, that won't happen until you've dragged everything in the right panel into the categories at the left.
Ideally the right panel would be empty or nearly empty.
But, before you do this and given the complexity of your Start Menu, please do a backup of your current Start Menu structure just to be on the safe side: Main -> Backup Start Menu.
Then you can do everything in one go or do some changes, hit Apply, make sure the changes were applied to the Start Menu, and so on...
PostPosted: Wed Oct 27, 2010 2:21 pm
cool that was it
all i did was move all the unsorted stuff into a new category to fix up later
and works great thank you
PostPosted: Wed Nov 17, 2010 1:07 am
I had same issue- the standard win 7 (64)start menu comes up instead of winstep modified start menu - and all my shortcuts are indeed catagorized - rebooted, etc - still there is no relationship to win step menu organizer and the start menu. Help! Thanks.
Peter
PostPosted: Wed Nov 17, 2010 8:24 am
Can you please post a screenshot showing the SMO and the Windows 7 Start Menu with the content of 'All Programs' visible? Just press the PRTSCN key to capture the screenshot with the Windows Start Menu open and paste the image into a paint program.
PostPosted: Wed Nov 17, 2010 1:34 pm
You nailed it - The new menu shows up in "All Programs", not in the root menu. Many thanks.
Peter
Users browsing this forum: Amazon [Bot], Google [Bot], Majestic-12 [Bot] and 165 guests
