 Post subject: image preview
PostPosted: Fri Apr 08, 2011 8:34 pm
hi there,
the image preview in nextstart-menus doesn´t work for me.
movies and jps can´t be displayed, only pngs.
in a prior version it works.
any suggestion why?
thanx
 Post subject: Re: image preview
PostPosted: Fri Apr 08, 2011 8:52 pm
11.2 allows you to specify which file types display a thumbnail. Perhaps you changed it by accident? The information is shared between WorkShelf and NextSTART.
Open WorkShelf Preferences -> Advanced tab -> Advanced button -> Thumbnail File Types button.
PostPosted: Fri Apr 08, 2011 9:07 pm
thanx for quick reply.
yeah, didn´t see that point.
but jpg etc is selected!
but i just see the standard-pic as preview for all images.
for movies there´s a preview-image but not a preview-movie, like it should.
PostPosted: Sat Apr 09, 2011 1:52 am
Excuse me? Why "should" it show preview movies? You mean, if I preview a directory full of movies, I "should" get a shitload of icons, all showing small videoclips?!!!
Umm... try, no...
PostPosted: Sat Apr 09, 2011 3:25 am
Sorry? What exactly do you mean? Preview images are static.
PostPosted: Sun Apr 10, 2011 9:52 pm
hmm ok, i thaught that it was like this (preview-clip for movies) in version 10.9. so i rembered wrong.
but any idea, why the preview of jpgs doesn´t work?
when i rename the pics from xxx.jpg to xxx.png it works...
i tried to change the standard-program for opening jpgs, but didn´t help.
PostPosted: Mon Apr 11, 2011 2:02 am
Do you see those JPGs as thumbnails in Explorer when you chose 'Large icons' or as simple icons?
I ask this because Winstep doesn't do the actual rendering of thumbnails, it re-lies on Windows to give it the thumbnail. If it doesn't show a thumbnail in Explorer, it won't show a thumbnail in Winstep.
Also, are you sure .JPG is in the list instead of just .JPEG?
PostPosted: Mon Apr 11, 2011 11:05 am
jpg is selected and in windows explorer i can see the preview thumbnails.
maybe i could help when i install a picture viewer programm like acdsee again?
PostPosted: Tue Apr 12, 2011 12:28 pm
for the icons of elements in docks or in the shelf it´s the same.
if i choose a jpg-image as icon, it can´t be displayed.
PostPosted: Tue Apr 12, 2011 12:59 pm
Well, I don't know. Works here and nobody else is complaining.
What do you have associated to JPG files in your system (i.e.; what program do they open in if you double click a JPG file)?
Also, what is your Windows version? 32 or 64 bit?
And finally, have you tried already clicking the 'Default' button in WorkShelf Preferences -> Advanced tab -> Advanced button -> Thumbnail File Types ?
PostPosted: Tue Apr 12, 2011 2:29 pm
yes it´s really a miracle.
i already pressed the "standard"-button in filetypes.
and i tried to associate jpg with different programs in windows. acdsee, google-picasa, windows standard viewer)
i also tried to completely remove an reinstall winstep extreme and searched the whole registry for entries...
my system is windows 7 32bit.
so, i think i gotta give it up.
PostPosted: Tue Apr 12, 2011 4:23 pm
Err, this might be stating the obvious, but since I forgot to ask in the first place: are you sure the 'Show document, image and video files as thumbnails' setting is enabled in WorkShelf Preferences -> Advanced tab -> Advanced button?
If it's not that, something else for you to try, although you would get no thumbnails in Explorer either if this wasn't set properly:
Go to Control Panel and then open Folder Options. In there you should go to the View and under Files and Folders you'll see "Always show icons,never thumbnails". Remove the check mark in that box and then click on Apply at the bottom right. You might also want to make sure that there is a check mark in the box next to "Display file icon on thumbnails".
PostPosted: Thu Apr 14, 2011 3:14 pm
according to what you said gorge as long as i can see the thumbnails in windows explorer i should see them in workshelf. i just checked my movies folder for mkv videos again and i do get the thumbnails in explorer. i copied a mkv to the desktop and then clicked the desktop tab and still it is just the default icon. i even went in and unchecked the show option in advanced options, applied, then went in and rechecked and applied and still no mkv thumbnail.
EDIT:
i also rechecked that mkv is in the right hand column for file types to generate thumbnails for.
if it helps:
win 7 pro x64
both the 32 and 64bit klite codec pack
divx codec pack
PostPosted: Thu Apr 14, 2011 3:32 pm
Some Codec paks will display thumbnails for 64 bit applications but not for 32 bit applications - and vice-versa.
This should be unrelated to this discussion because the rendering of JPG thumbnails is built-in into the system.
PostPosted: Thu Apr 14, 2011 5:09 pm
ok can you move my previous post, your post and this one to a new thread the?
as for the codec packs generating thumbnails i know from experience both the 32 bit and 64 bit packs do for klite as well as the divx codec pack do generate thumbnails. i installed each pack independent of each other after clean installs of windows and had my mkv thumbnails each time, so it is not a matter of if the codec packs do or don't, because each of them does show mkv thumbnails in explorer.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 212 guests
